Forums >> Revit Building >> Technical Support >> Will not Dimension to Studs
Thu, Jul 17, 2008 at 9:58:41 AM | Will not Dimension to Studs
Trowell
I am using Revit 9.1. I want to dimension to the studs/ framing but it wants to dim. to center or OSB. Is there a box I have not checked? Please help.
Thu, Jul 17, 2008 at 10:19:16 AM | Will not Dimension to Studs
Trowell
Sorry for wasting your time. It was the same thing I was doing for my other post. I had the OSB in the core category. When I moved it above the core it dim. to the studs.
Thu, Jul 17, 2008 at 11:01:25 AM | Will not Dimension to Studs
Trowell,
Although you have learned something with your experience it was not your problem. No matter what your dimension settings are on the options bar (core face, wall face, wall centerline)  you can dimension to any component line within a wall by tabbing when you hover near the line.   There are some wall where you may want to define some elements as core but still dimension to something else.
Fri, Jul 18, 2008 at 9:00:38 AM | Will not Dimension to Studs
Trowell
Thank you for your help.
How to create a 2x6 wood stud
Wed, Oct 16, 2013 at 2:24:57 PM
Wood studs
Mon, Mar 31, 2008 at 2:24:59 PM
wall pattern with studs and insulation
Sun, Oct 28, 2007 at 12:37:22 PM
Counting in the schedules
Fri, May 18, 2012 at 1:23:01 PM
Metal Studs as Beams
Fri, Mar 28, 2008 at 3:48:15 PM
Page generation time: 2.5063
