Forums >> Revit Building >> Technical Support >> Door Family Editing
Thu, Jul 17, 2008 at 9:55:51 AM | Door Family Editing
zabel
Trying to make a hollow metal framed door starting with the regular flush door from the Library, and don't understand some of the fundamentals...
How is the wall opening defined in the door family?  At first I thought it was the "left" and "right" reference planes, but changing their status to Weak Reference and establishing a new plane as "left" has no effect on the wall opening.
I'm sure it's easy enough to find and download a HM door, but I want to understand the nuts and bolts!
Thanks!
Thu, Jul 17, 2008 at 10:57:36 AM | Door Family Editing
4 Stars: 205 Votes
Hi, to create "a hollow metal framed door" you can do this with the "SOLID SWEEP" around of your door, by the way, LOCK all the lines to constrain to the door and wall...
Edit/Add trim to Door Family
Thu, Jan 14, 2016 at 10:02:29 AM
Storefront Door Editing
Fri, Jul 30, 2021 at 3:39:16 PM
linewidth of elements in family editing
Wed, Feb 16, 2005 at 11:21:50 AM
Multi Panel Sliding door that is actually a Window Family
Fri, Feb 20, 2009 at 7:22:04 AM
Door family construction
Mon, Feb 15, 2010 at 10:14:22 AM
13
Page generation time: 0.9650
