Forums >> General Discussion >> Revit Project Management >> Ceiling Heights in schedule????
Thu, Jul 17, 2008 at 9:39:42 AM | Ceiling Heights in schedule????
andymeyer50
Is there a way to edit the room finish schedule so the ceiling height category shows the "height offset from the level" number (the actual height of the ceiling above the finish floor in the model), instead of the "limit offset" number that appears to have nothing to do with the actual height of the ceiling in the model? Any help would be greatly appreciated.Thanks!!!
Tue, Aug 19, 2008 at 3:04:17 PM | Ceiling Heights in schedule????
LIZARD2806
3.5 Stars: 7 Votes
Unfortunately, Revit for some reason does not allow the ceiling height to be added to a room schedule, despite all the information being there.  (If you made a ceiling schedule, you could add the height offset from level to the schedule).  In any event, luckily the workaround is not that difficult.
1.  Go to "Settings", "Area and Volume Calculations..." and make sure that "Areas and Volumes" is selected.  Say OK.
2.  In your room schedule, add the Volume and Area fields to your schedule, then.....
3.  Select the "Calculated Value" button, change the Name to "Ceiling Height", change the Type to "Length", then in the Formula box, type "Volume/Area" (w/o quotation marks).
4.  Assuming your model is accurate, you should now have the ceiling heights in your schedule.
HTH
**Using Revit Architecture 2009, 2011, and 2012**
Wed, Aug 20, 2008 at 2:25:17 PM | LIZARD2806
NKramer
4 Stars: 9 Votes
Quoting LIZARD2806 from 2008-08-19 15:04:17
Also assuming that your ceiling is flat....
We actually ended up removing all ceiling information from our room schedules and just use tags now. Not the old company standard, but its smart and works better.
Nick
Wed, Aug 20, 2008 at 2:45:48 PM | Ceiling Heights in schedule????
LIZARD2806
3.5 Stars: 7 Votes
Absolutely correct.  Flat AND level.  I was thinking about that when I was replying, but forgot to type it.  Thanks for catching me, NKramer.
Ceiling heights in schedules
Thu, May 26, 2005 at 9:26:42 PM
CEILING HEIGHT IN SCHEDULE
Mon, Feb 18, 2019 at 6:34:48 PM
Tagging multpile ceiling heights in the same plan
Tue, Jan 8, 2008 at 4:46:30 PM
Ceiling height column problem in schedules
Fri, Dec 7, 2007 at 10:23:16 AM
Apartment Groups - Ceiling heights
Mon, Jul 21, 2014 at 11:11:51 AM
Page generation time: 0.2341
