10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> black screen and unfinished renders
4 Posts No Rating |
revit 2009 screen stays black when i render. also when i use the demo mep revit my renders dont finsih.please help
Are you rendering internally? If so, have you updated your light fittings to 2009? This is a separate process. Check out my blog as this is one of things I've gone through in the presentation I did at RTC.
Regards,
Chris.
I'm having a similar issue, but can't find what you are talking about on the blog.... could u post a link possibly? thanks!
4 Posts No Rating |
I have also had a similar problem. With an earlier project I had no problems rendering. I have since installed Architecture 09, and I now get the black screen when rendering. I haven't really looked into this, but I have a feeling I may have deleted my material library. This may be worth checking out. If you have no materials it will have nothing to render.
1 Posts No Rating |
I teach Revit 2009 in a classroom setting with 24 High School students currently rendering their projects. 6 of theses student projects have similar problems, black or very dark renderings. All students have the same hardware setup. We solve the problem by creating a new outside camera shot, not trying to render the 3D model. This solution has worked every time. I sure don't knot why.
my renders stays with black svreen |
Fri, Jul 18, 2008 at 5:33:13 AM
Rendering Interior Light is not working, black screen. |
Fri, Dec 14, 2012 at 9:26:37 AM
HELP!~ Black Screen Patch |
Mon, Oct 27, 2025 at 2:06:53 AM
Renders with artificial lighting on result in high saturation and black patches |
Tue, Jun 21, 2016 at 7:29:28 PM
Black annotations on black screen |
Mon, Jun 20, 2016 at 2:18:39 PM
