15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> text symbols
we are recent new users and want to insert degrees and diameter symbols in text. is there a revit way, rather than the alt plus number method?
Nope...
Only the character map shorcuts ATM.
Which in my preference is just as easy. Most monitors in our office have a post it stuck to them with a list of the most common used symbols.
69 Posts No Rating |
How can I find those if I don't have the post it!
latemore back. thanks mr spot. i checked it, and works fine on a normal keyboard, but not my laptop. as others may be asking for the codes, i am attaching some shortcuts.
1 Posts No Rating |
Great info, and thanks for the shortcuts. Is there anyway to use codes on a laptop?
The codes need to be typed in on a laptop using the 'numbers' keys not the ones above the qwerty letter keys. Some laptops have the numbers keys that can be activated with a special Fn key. Check your laptops documentation to see if you have such a feature. You can also add a USB num pad which should work. Another option is to insert the characters by using a copy paste method from MS Word or by using the Windows charmap utility [Windows>Start>Run>charmap]
Text symbols [ 1 2 ] |
Tue, Mar 10, 2015 at 10:14:14 PM
18
Text Symbols? [ 1 2 ] |
Tue, Apr 28, 2009 at 2:43:34 PM
22
symbols in text |
Tue, Apr 4, 2006 at 11:52:47 AM
The ability of adding text or symbols into line patterns |
Thu, Oct 30, 2014 at 2:45:39 AM
Text Styles |
Tue, Aug 4, 2009 at 9:59:13 AM
