12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Killing error while saving file to central
When i do save to central it gives the error { Element 4593824 became corrupt at some time before this session}. Everytime i have to audit and purge the central file and it works for approx. half an hour and then comes the same error with different element Id. I could delete few elements but now it showing that element do not exist anymore. Please help as i have submission tomm....... :-(
Now on the implementation stage.... |
The only way I have found to fix this type of issue is to revert back to a backup file. What version are you using?
We r using Revit architecture 2008. IS there any other way to do it?
2 Posts No Rating |
same problem here anybody has figured a way to fix it?
Do continuous audit nd it will get fixed whn u r lucky :-) GUDLUCK
2 Posts No Rating |
removing a linked Revit file apparently solved the problem...have not had any more corrupted element errors in two days.....
Saving to Central |
Thu, Mar 12, 2009 at 9:42:05 PM
Can not create local file from Central |
Tue, Mar 6, 2012 at 11:57:26 AM
Shared Coordinates Error When Saving |
Wed, Sep 10, 2008 at 1:42:09 AM
Error - Local File Resides in Central File Location |
Fri, Apr 9, 2010 at 8:34:55 AM
Revit 2009 error message from linking |
Mon, Sep 22, 2008 at 9:58:17 PM
