Forums >> Revit Building >> Technical Support >> Plotting? What the #@// ??
Wed, Jul 16, 2008 at 9:14:43 AM | Plotting? What the #@// ??
rquist
spent about 3 hours in the Revit plot dialogue boxes and hp430 printer preferences dialogue box; feel like I can't even tie my shoes !!
sometimes I get the middle 3/5ths of the titleblock sheet with the same portion of the drawing
sometimes I get a portion of the drawing with no title block
Not really seeing any information in Revit "help" menu.
Where's the absolute first place to start for satisfactory plotting??
Wed, Jul 16, 2008 at 12:07:49 PM | Plotting? What the #@// ??
Belinski
4 Stars: 5 Votes
Hey,
Pick the appropriate size paper in the settings menu, and if it is half size then zoom 50 percent, full size then zoom 100 percent.
Wed, Jul 16, 2008 at 12:27:26 PM | Plotting? What the #@// ??
Westview
2.5 Stars: 2 Votes
PICK CENTER PLOT ALSO.
Wed, Jul 16, 2008 at 1:05:34 PM | Plotting? What the #@// ??
lunchtrayrider
3.5 Stars: 7 Votes
sometimes if you define margins at 0 that can work better then center plot (although center plot is most times)
file>print>set-up>offset from corner>no margins
Edited on: Wed, Jul 16, 2008 at 1:06:41 PM
I like scooters. and motorcycles.
Fri, Jul 18, 2008 at 12:37:31 PM | Plotting? What the #@// ??
rquist
can't quite get my titleblock to completely show up when plotting.
 I've included a screen shot showing plot preview and dialogue box settings.
Any thoughts,
thanks
randy
Fri, Jul 18, 2008 at 12:37:39 PM | Plotting? What the #@// ??
rquist
Any thoughts,
thanks
randy
Fri, Jul 18, 2008 at 12:56:12 PM | Plotting? What the #@// ??
You forgot the screen shot.
If your plot driver is just not friendly to REVIT, you might look at using something like CutePDF writer to make a PDF which you can then print to the plotter.  We use this program for plot files which we send to our commercial print company.
Have you got the latest plot driver for your plotter loaded?  This should not be as hard as you are having.  Rember, this is not autocad.  Either just plot full size on the correct size paper or plot to fit/zoomed on whichever paper you pick.
Fri, Jul 18, 2008 at 1:15:48 PM | Plotting? What the #@// ??
rquist
thank you
this should be the screen shot
Fri, Jul 18, 2008 at 3:40:40 PM | Plotting? What the #@// ??
Westview
2.5 Stars: 2 Votes
I am not sure what size paper you are plotting on but I noticed you had picked ANSI C (17x22) is this the same sise as your title block? The title block offset should be 1/4" to 1/2" from the right depending on your plotter.
Fri, Jul 18, 2008 at 4:41:22 PM | Plotting? What the #@// ??
rquist
good point.
trying to plot on 18 x 24
I can't pick that size from the plot dialogue box. only option is for c size is 17 x 22.
should I just resize my title block or is there a way to access an 18 x 24 sheet through the plot dialogue box.  I suppose that would be the custom size paper settings?
 we have an older hp design jet 430 (black and white printer) if that matters
Fri, Jul 18, 2008 at 7:14:24 PM | Plotting? What the #@// ??
#11
Westview
2.5 Stars: 2 Votes
You can go into the properties and create any paper size you want by picking custom paper size and give it a name. Then use that size paper for your plots. I am not sure what the bigger companys use but I use ANSI D 22 x 34 so I can print at 50% on 11 x 17 on my office printer for reviewing before the final plot.
plotting to a plotting service plotter with a prn file
Wed, Jun 4, 2008 at 1:14:56 PM
Plotting PDF's
Tue, Jul 21, 2009 at 4:18:05 PM
Plotting HELP!!
Tue, Nov 14, 2006 at 3:13:10 PM
Plotting
Fri, Apr 28, 2006 at 8:31:02 PM
plotting problem
Wed, Dec 22, 2004 at 3:44:51 PM
Page generation time: 0.3543
