11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Cadd architectural site plan mystery
Ill start by giving you some background- our firms in house survey people have created in civil 3d/autocad an incredibly large detailed site plan that contains EVERYTHING I want to import it (minus a few layers) in revit for an architectural site plan, I have tried freezeing, and turning off all of the unwanted layers and importing it checking the box to import ionly visible layers but every time ALL of the layers come in and are visible. If I link it then only a few layers come in and some of the ones I need do not. what do I do in Revit/cad to bring in only the layers I want? Thanks in advance
Hi, in CAD save the file with other name, then open and delete everything what do you don't need, then purge and go to revit and import the file...
so thier is no way to do it without deleting, I only ask because I was hoping to be able to use the file for multiple imports and was hoping not to have to make a bunch of files? Thanks
You also can do in revit, pick the Import file, in top menu pick in "QUERY" and select what do you wnat to delete or hide in view...
Thanks, Thats exactly what I wanted to be able to do.
YOU WELCOME...
revit 2011 Coordinate points issue |
Wed, Nov 17, 2010 at 5:50:21 AM
Importing Revit Layers into Auto CADD |
Mon, Nov 19, 2007 at 8:09:11 PM
Putting walls on different layers CADD teacher needs help. |
Mon, Apr 14, 2008 at 9:13:10 AM
site plan disappears intermittently |
Thu, Mar 16, 2017 at 9:21:12 PM
Problem with Reigion Hatching on Site Plan [ 1 2 ] |
Tue, Feb 25, 2014 at 4:19:15 PM
26
