Forums >> Revit Building >> Technical Support >> How to map images
Tue, Jul 15, 2008 at 11:55:42 PM | How to map images
schuss
I need some help mapping an image on to an object.  ie:  a photo of a site plan, and need to be able to see it in my viewport.  I have absolutely no idea what to do.  Please help.
Wed, Jul 16, 2008 at 5:07:55 AM | How to map images
4 Stars: 205 Votes
Hi, you can use that image, in your viewport go to the left menu, "Modelling>DECAL" browse the image and put them in a object you wand then adjust the decal...
Wed, Jul 16, 2008 at 7:21:10 PM | How to map images
schuss
Thanks, that's a great start, but how can I see image in my viewports?
Wed, Jul 16, 2008 at 10:36:04 PM | How to map images
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Decals only display when you render.
You can place an image of your site plan on a sheet then drag your plan view over the top and providing you haven't modelled the topo then it should show through.  You may need to turn off floors or topo if you have.
Regards,
Chris.
MAP TEXTURE IMAGES TO ELEVATIONS AND FLOOR PLANS
Mon, Mar 5, 2007 at 2:39:54 PM
Material image map problem
Mon, May 11, 2009 at 2:37:29 PM
2d Location Map
Tue, Nov 8, 2005 at 4:58:49 PM
site map?
Thu, Oct 4, 2007 at 3:31:36 PM
REVIT users map
Wed, Sep 27, 2006 at 12:14:05 PM
Page generation time: 0.1178
