14 Users Online (11 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Phasing and Room Tag
Thu, Apr 14, 2005 at 12:24:14 PM | Phasing and Room Tag
jingle
Right now I have 3 phases: existing, demolition and new construction. But later I have to show the existing room tag on the demolition plan. Because the room tag is phase-specific, the only way I can figure out is merging the existing phase and demolition phase. However, after I did combination, the phase filter doesn't work well. I must use “show all” instead of “show previous and demo” to see the existing & demolition plan…it doesn’t make any sense. Anybody knows the problem? Thanks!
Thu, Apr 14, 2005 at 4:59:46 PM | RE: Phasing and Room Tag
jingle
nobody knows??????please help!
Thu, Apr 14, 2005 at 5:26:50 PM | RE: Phasing and Room Tag
TomDorner
4.5 Stars: 25 Votes
Room tags are view specific. You can copy them from one view to another. You have to watch out though as sometimes a room exists in one phase but not the other. Remember, Revit is a database and the room tags "report" the properties of the room not define the room. There is a discussion of this issue on AUGI if you go over there and do a search. Tom
Thu, Apr 14, 2005 at 7:00:08 PM | RE: Phasing and Room Tag
jingle
thanks Tom! i checked info there,doesn't help a lot. anybody knows more? Post edited on 2005-04-14 19:58:21 Post edited on 2005-04-15 13:28:31
Sun, Apr 17, 2005 at 8:26:22 PM | RE: Phasing and Room Tag
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Revit will not allow you to show previous phase tags in a later phase. Workaround: Duplicate your existing plan and turn off everything except the room tags. Then on a sheet overlay this plan over your demolition plan (it will snap into place). This will retain all the automation of these tags and still essentially show all the information you need. For this room tag view also set the view title to none. HTH.
Mon, Mar 16, 2009 at 3:06:51 PM | Phasing and Room Tag
jmqrsq
5 Stars: 3 Votes
IS THIS WORKAROUND STILL NECESSARY WITH rEVIT 2009/2010? I AM HAVING THE SAME ISSUE BUT FOR EXISTING ROOM  NAMES SHOWING UP IN NEW PLANS FOR ADJACENT AREAS
Wed, May 26, 2010 at 9:06:44 AM | Phasing and Room Tag
nickmaguy
You can also just leave the existing rooms as "new construction" in the plan, and just filter them out of your new construction room schedule. I just wrote "existing" in the comments parameter of the rooms that are supposed to be existing rooms and filtered by: comments - does not equal - existing. I don't see too many drawbacks to this.
 Nick
Wed, May 26, 2010 at 9:47:45 AM | nickmaguy
TomDorner
4.5 Stars: 25 Votes
Quoting nickmaguy from 2010-05-26 09:06:44
 Nick
 Huge, Huge Danger!  Other people in the process rely on rooms placed correctly for energy analysis, HVAC zoning, quantity take-offs etc. etc.  If BIM is to be achived, then data centric solutions need to be employed not CAD centric solutions.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Wed, May 26, 2010 at 2:17:23 PM | Phasing and Room Tag
Bimman
Bimman Avatar
1 Stars: 2 Votes
would be nice if this would get addressed. i dislike having to do a work around for this each time we do renovation project. it doesn't seem like it would be all that difficult, hey but i not a programmer.
PWD
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:40 AM
Phasing is interfering with Room Area/Tags (I think)
Wed, Sep 28, 2016 at 1:15:48 PM
Keynote or Room Tag
Fri, Feb 5, 2010 at 1:08:31 PM
Page generation time: 7.9997
