Forums >> Revit Building >> Technical Support >> Creating a net?
Tue, Jul 15, 2008 at 1:21:58 PM | Creating a net?
mdd982
Is it possible to create a net in Revit? I am modeling a hockey rink which has protective netting above the glass. Would I have to download something for this? Thanks.
Tue, Jul 15, 2008 at 1:53:48 PM | Creating a net?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
You could probably created a curtain system with empty panels and a thin circular mullion profile as the threading. That way you are able to adjust the spacing and appearance. Or possibly create a family and use a few different length parameters, then use model lines with a large thickness to create the netting. Just brainstorming it seems like there are several options for this depending on the type of control you would like to have over the object.
Tue, Jul 15, 2008 at 2:01:42 PM | Creating a net?
mdd982
What? I'm asking if there is a way to create a net.
Tue, Jul 15, 2008 at 4:45:25 PM | Creating a net?
Alabaster's thought process is interesting but it would take a lot of components and really eat up the memory.  We needed a mesh (net) so we used a metal screen bitmap.  It will render correctly but shows as a solid in your 2D work.
Tue, Jul 15, 2008 at 6:09:49 PM | Creating a net?
Debo
Why cant u just create the shape of the net with an extrusion or sweep and apply a hatch pattern to it...
Tue, Jul 15, 2008 at 8:08:39 PM | Creating a net?
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, do these pictures show what you want? The big wall is there to show that the net is transparent, and no rendering has been used.
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Wed, Jul 16, 2008 at 6:45:50 AM | Creating a net?
timbo89 .... will that render?
Wed, Jul 16, 2008 at 7:00:03 AM | Creating a net?
4 Stars: 205 Votes
Hi create a Wall for example, and assign the material i post....
Wed, Jul 16, 2008 at 7:27:02 AM | Creating a net?
4 Stars: 205 Votes
Look the render in medium settings...
Edited on: Wed, Jul 16, 2008 at 7:49:45 AM
Edited on: Wed, Jul 16, 2008 at 7:51:21 AM
Wed, Jul 16, 2008 at 7:41:17 AM | Creating a net?
Typhoon - did you say you posted the material?  What name?  Thanks.
Wed, Jul 16, 2008 at 7:46:36 AM | Creating a net?
#11
4 Stars: 205 Votes
Hi WWhub i don't put the material, only the image but i put now...
Pick in the image and save as... or in the folder in revit directory "LOW RES" choose "FENCE03", you have severals with diferent kink of fences...
Edited on: Wed, Jul 16, 2008 at 7:48:07 AM
Edited on: Wed, Jul 16, 2008 at 7:54:37 AM
Tue, Nov 10, 2009 at 7:09:50 AM | Creating a net?
#12
NCBigC
Typhoon,
your net rendering is exactally what I am trying to achieve.  I have saved the image that you have suggested. I created a wall that was only a 1/8" thick and applied the image you posted as the material.  However, when I rendered it, it was not transparent as your rendering showed.  It kept the black background. How did you accomplish the transparent effect?
Tue, Nov 10, 2009 at 1:17:20 PM | Creating a net?
#13
4 Stars: 205 Votes
Simple, are you looking the image i post now?
Tue, Nov 10, 2009 at 1:42:48 PM | Creating a net?
#14
NCBigC
That worked great. Thanks.
Does that "cut out" feature always work with just a black background?
Tue, Nov 10, 2009 at 1:50:32 PM | Creating a net?
#15
4 Stars: 205 Votes
Why don't you try and then you tell me?
net windows
Wed, Sep 30, 2009 at 11:02:55 AM
Diagonal cross net railing panel
Mon, Mar 4, 2019 at 9:52:39 AM
Tenis Net
Thu, Dec 20, 2007 at 1:05:13 PM
Central-file sharing over the net?
Wed, Jan 14, 2009 at 5:22:34 AM
Creating organic/free form entrance and display wall - revit 2011
Sun, Nov 7, 2010 at 6:25:12 PM
Page generation time: 0.2054
