Forums >> Revit Building >> Technical Support >> Revit 2009 Rendering Problem(Black screen)
Mon, Jul 14, 2008 at 8:11:28 PM | Revit 2009 Rendering Problem(Black screen)
unn7
Hello People, I'm a student who study architecture.
I found this problem in several PCs.
When I pushed Rendering button, it takes just 1 second to complete rendering, and there is just a black screen
instead of realistic image. It's just all black. I found some PCs have this same problem, and others have not.
I'm sure that there are no problem in the path of rendering folder.
Does anybody know how to solve this problem??
Mon, Jul 14, 2008 at 8:15:58 PM | Revit 2009 Rendering Problem(Black screen)
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Did you do an exterior or interior render? What lighting scheme did you use?
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Mon, Jul 14, 2008 at 11:17:26 PM | Revit 2009 Rendering Problem(Black screen)
unn7
Surely, I tried every light options.
 And there is another fact that I found. Acctually, I used to be able to render through RAC2009,
But after I upgrade my hard to new one, it doesn't work anymore. So I think some hardware setting is different.
Cause some friends have exactly same Hard disk with me, but they can use renderer in RAC 2009.
 I really cannot get the answer in anywhere.
Tue, Jul 15, 2008 at 4:22:57 AM | Revit 2009 Rendering Problem(Black screen)
4 Stars: 205 Votes
It must be something with the graphics card...
Tue, Jul 15, 2008 at 6:02:31 AM | Revit 2009 Rendering Problem(Black screen)
unn7
But I upgraded my graphic card driver as same ver. of previous status. I don't think it's graphic card problem.
Tue, Jul 15, 2008 at 5:37:57 PM | Revit 2009 Rendering Problem(Black screen)
timbo89
timbo89 Avatar
4 Stars: 5 Votes
This may seem obvious, but do you have the sun settings and time set to night?
Wed, Jul 16, 2008 at 12:42:08 AM | Revit 2009 Rendering Problem(Black screen)
unn7
I checked my sun settings, and tried re-setting the time, but I think the options are not related to this symptom.
Wed, Jul 16, 2008 at 12:47:33 AM | Revit 2009 Rendering Problem(Black screen)
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Can you upload the file so we can have a look at it?
Wed, Jul 16, 2008 at 12:57:57 AM | Revit 2009 Rendering Problem(Black screen)
unn7
Here is a capture image. I don't think you can read the text. Cause it's Korean Version.
But as you see, the render time is just 2 second, and there is just black color on the screen.
and I set every settings correctly. I used revit 2009 renderer for last project, so I know about the settings enough.
Wed, Jul 16, 2008 at 5:12:18 AM | Revit 2009 Rendering Problem(Black screen)
4 Stars: 205 Votes
Don't help nothing....
Wed, Jul 16, 2008 at 9:34:06 AM | Revit 2009 Rendering Problem(Black screen)
broncos4life
3.5 Stars: 11 Votes
Upload your project with this website and post the link to the file and we can all take a look at it.  List what view you are trying to render and we can try it out.
http://www.filedropper.com/schmaticdevelopment3
Mon, Aug 11, 2008 at 4:01:07 AM | Revit 2009 Rendering Problem(Black screen)
chuaheyia
chuaheyia Avatar
3 Stars: 2 Votes
it's odd to think that you cannot produce high resolution images with revit architecture 2009 - but, we cannot if we max out all the setting - everything goes to a halt - it crashes.
Mon, Aug 11, 2008 at 7:14:07 AM | Revit 2009 Rendering Problem(Black screen)
#13
chiragpklg
4 Stars: 11 Votes
There must be sum problem with ur rendering settings but as it is in korean language we can't make it out, sorry
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Mon, Aug 11, 2008 at 9:15:43 AM | Revit 2009 Rendering Problem(Black screen)
#14
chiragpklg
4 Stars: 11 Votes
I think I got the solution to your problem, have you checked the lighting scheme, cause when it is set to Interior artificial only it renders & nothing is shown except black screen I have attached an image for your reference.
Chirag C. Pawar
Tue, Nov 25, 2008 at 11:18:30 AM | Revit 2009 Rendering Problem(Black screen)
#15
napoletano
I have the same problem. With an exterior scene I set both sun and artificial light and the rendering process stops at 10% and I get only a black screen. If I set the quality a draft it works. Could be se size of the file?
black screen and unfinished renders
Tue, Apr 21, 2009 at 7:28:17 PM
Rendering Revit Architecture 2009 - Little Black dots!!!!
Fri, Dec 19, 2008 at 5:42:49 AM
Revit Black Screen of Death?
Wed, Jul 15, 2009 at 8:53:05 AM
Black annotations on black screen
Mon, Jun 20, 2016 at 2:18:39 PM
HELP!~ Black Screen Patch
Mon, Oct 27, 2025 at 2:06:53 AM
Page generation time: 1.7588
