Forums >> Community >> The Studio >> Scale of Text in Views?
Mon, Jul 14, 2008 at 6:11:25 PM | Scale of Text in Views?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Can the scale of the text in a view change with the scale of the view when changing the scale of that certain view?  I know Autocad does this and I was just wondering if there was a way to make Revit do it as well.
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Tue, Jul 15, 2008 at 7:11:53 AM | Scale of Text in Views?
The great thing about REVIT is the text size stays the same no matter what scale the view is set to.
Tue, Jul 15, 2008 at 7:21:44 AM | WWHub
4 Stars: 205 Votes
Quoting WWHub from 2008-07-15 07:11:53
"The great thing about REVIT is the text size stays the same no matter what scale the view is set to. "
DITTO...  (like Coreed says)
Thu, Jul 17, 2008 at 4:35:23 AM | Scale of Text in Views?
geraldr
I can see why it would be helpful if the text could change scale.
For example you draw a plan at 1:50 and have dimensions and room tag text which sits nicely in proportion with the drawing. You then set up a sheet and wish to have the plan views at 1:100. The text then is too big for the plan.
 Can it be set somewhere to change automatically?
Thu, Jul 17, 2008 at 5:44:16 AM | Scale of Text in Views?
coreed
coreed Avatar
4 Stars: 16 Votes
the size of the text really does not the stay the same size. the size of the text ia adjusted according scale so that
 the print size of the text stays the same. the text itself actually changes in size depending on the given scale.
HTH
Edited on: Thu, Jul 17, 2008 at 5:45:01 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jul 17, 2008 at 7:37:17 AM | Scale of Text in Views?
coreed ...  I should have qualified my statement by saying the size of the printed text stays the same.  The size of the text relative to the model adjusts.
Old AutoCAD users always thought about text relative to the "model" and had to adjust.  After AutoCAD added paper space, I preferred doing annotations and dimensions in paper space.  That's why REVIT was so easy a transition for me.  Revit really treats all dimensions and annotations as "paper space" elements in that they always print the same size relative to paper not view scale.
View Title scale text won't show
Tue, Dec 29, 2009 at 2:36:51 PM
stairs up & down text cannot be moved
Thu, May 8, 2008 at 7:26:11 AM
Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
Mon, Aug 29, 2011 at 7:58:12 AM
Text as a Graphic
Mon, Mar 23, 2009 at 4:54:18 PM
Can someone explain text scale to me?
Fri, Nov 14, 2008 at 9:17:35 PM
Page generation time: 0.8122
