Forums >> Revit Building >> Technical Support >> Soffit Sweep / Roof Facia
Mon, Jul 14, 2008 at 12:50:22 PM | Soffit Sweep / Roof Facia
mflure
Greeting all,
Started a big house project and I'm trying to figure out if anyone has found some kind of workaround for a Soffit/Roof Facia sweep.  I have a Spanish type stepped cove soffit that it around the entire perimeter of the roof soffit using Roof Facia sweeps.  Everything works fine except when I get to a gabled end, then it doesn't want to "clean-up" to the soffit that is on the adjacent to the Hip ends no matter what option I choose.  Didn't know if I should be doing something different? Or if someone has a workaround or a different approach.
Thanks,
Mike
Mon, Jul 14, 2008 at 2:28:09 PM | Soffit Sweep / Roof Facia
kesflower
3.5 Stars: 11 Votes
What rafter cut are you using on the roof?  Soffits and fascias really only like to clean up when they are used on a "Two-cut Square" rafter cut
Ruth Rau
Main Street Architecture, P.C.
Mon, Jul 14, 2008 at 3:06:39 PM | Soffit Sweep / Roof Facia
4 Stars: 205 Votes
Hy, can you put some screenshots to figure out?
Modify Roof Facia
Wed, Feb 28, 2007 at 2:22:39 PM
Roof overhang not following 2" Facia Square cut
Wed, Mar 5, 2008 at 10:33:05 AM
Gutters and Roof Facia Issues
Wed, Jul 25, 2007 at 9:08:42 AM
Roof soffit inexplicably (to me) showing up as 'beyond'.
Mon, May 7, 2012 at 11:09:14 AM
Get Roof Soffit To Have Same Rafter Cut As Roof?
Wed, Jul 16, 2014 at 7:37:35 AM
Page generation time: 0.5947
