Forums >> Revit Building >> Technical Support >> text note questions
Thu, Jan 22, 2004 at 10:02:27 AM | text note questions
Pyxis55
Can anyone tell me how to include symbols in text notes - like degrees, plus/minus, diameter, etc? Thanks, Karen Post edited on 2004-01-22 10:02:52
Karen Maxon LineWright
Thu, Jan 22, 2004 at 10:12:46 AM | RE: text note questions
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
have you tried using the keyboard command for making symbols? for instance, holding down the alt key and typing 248 will make a ° symbol. Num Lock must be on. Also, check out the following link for information on using the windows character map for symbols. http://csssrvr.entnem.ufl.edu/~walker/5810/04FNKBch.PDF
Hiroshi Jacobs
The Catholic University of America
Fri, Jan 23, 2004 at 3:20:01 AM | RE: text note questions
avenir
1 Stars: 1 Votes
Hi Karen, If what Hiroshi said didn't work for you. You can just simply open Windows Character Map under accessories. Just select the font you use and find the symbol in the library. Then just copy and paste it. Dave.
Mon, Jun 19, 2006 at 7:51:38 PM | RE: text note questions
vnd
3 Stars: 2 Votes
Why hasn't revit included an easier way to include degrees symbol?... isn't this symbol one of the most commonly used and integral part of building measurement symbols?
VND
Mon, Jun 19, 2006 at 10:38:49 PM | RE: text note questions
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Most programs that implement a tool to manage these "symbols" are generally just links to the windows character map. Why waste precious programming time doing this when there are far more pressing issues? My 2 cents.
Tue, Jun 20, 2006 at 4:57:01 AM | RE: text note questions
puzzle
4 Stars: 10 Votes
To get the degress symbol hold down ALT & hit + 0176 ° ALT & hit + 0178 for the 2 in metres square ² There are hundreds of combinations many are the same as the character map on windows.
Macca
Sunshine Coast
QLD Australia
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Schedule text erased when inserting new plan note
Tue, Feb 15, 2011 at 10:42:37 AM
Note Tags
Mon, Nov 10, 2014 at 2:26:25 PM
Levels and Keyed Note
Fri, Jul 6, 2007 at 2:21:49 PM
watermark note and level height units
Tue, Jul 21, 2009 at 1:37:50 AM
Page generation time: 1.9069
