Forums >> Revit Building >> Technical Support >> Modify a floor based fixture so it can attach to a roof
Fri, Jul 11, 2008 at 12:31:17 PM | Modify a floor based fixture so it can attach to a roof
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
So I am thinking of a clever way to attach the two suspension rods in a floor based pendant light to my roof since my second floor has an open ceiling. I tried adding some individual length parameters but it is too tedious to adjust them all. I was thinking I would like the suspension rods to act like a column does for attachment.
Best idea I have is to recreate the family in a face based template and figure out how to keep my light level to the floor and have the suspension rods attach to the sloped roof.
any bright ideas?
Fri, Jul 11, 2008 at 1:19:17 PM | Modify a floor based fixture so it can attach to a roof
Read this thread http://www.revitcity.com/forums.php?action=viewthread&thread_id=12162
Fri, Jul 11, 2008 at 1:42:32 PM | Modify a floor based fixture so it can attach to a roof
alabaster2513
3.5 Stars: 25 Votes
My problem is getting my 2 rods to host at variable lengths without manually inputting the length.
the lights are 10' long, some run parellel with the roof slope, some run perpindicular.
I can achieve the light being hosted to the roof but i am unable to keep the light fixture itself parallel to the floor on the lights that run parallel to the slope.
I tried messing with some angle and slope parameters but it just isn't going well.
Fri, Jul 11, 2008 at 2:12:12 PM | Modify a floor based fixture so it can attach to a roof
Did you check your always vertical box in your family?
Fri, Jul 11, 2008 at 2:48:15 PM | Modify a floor based fixture so it can attach to a roof
alabaster2513
3.5 Stars: 25 Votes
I was missing that. I almost have it. i can keep the light parallel, i can get it to adjust height from the floor.
this is pretty tricky. i need the suspension rods to attach to 2 different reference planes that I can adjust the distance between by inputting an angle. any thoughts on that one?
Fri, Jul 11, 2008 at 3:03:32 PM | Modify a floor based fixture so it can attach to a roof
There were discussions yesterday or the day before about making parametric counters that you could use your alignment tool to adjust their length.  You could do the same think here.  Same idea but vertical instead of horizontal.  Set a reference plane in the family that will be your inserted floor height.  When you insert the family, you can adjust the location height by finding this reference plan and stretching it to the floor.
Fri, Jul 11, 2008 at 3:59:18 PM | Modify a floor based fixture so it can attach to a roof
alabaster2513
3.5 Stars: 25 Votes
i added a parameter that calculates the length of the taller of the two suspension rods by inputing the roof slope.
Rod Length = Rod Spacing * tan(Roof Slope)
Made them all instance parameters and now it is fully adjustable by control points.
WOOHOO TRIG FUNCTIONS!
Attach floor edge to sloped roof
Mon, Nov 5, 2012 at 11:40:37 AM
Trying to Get my fixture to attach properly
Wed, Jun 17, 2009 at 11:33:04 AM
Displaying Recessed lights in ceiling
Wed, May 27, 2009 at 6:21:59 AM
face-based lighting fixture families questions [ 1 2 ]
Fri, Oct 24, 2008 at 12:17:51 PM
15
How would you modify a family from face-based or hosted to one that is not?
Mon, Sep 26, 2011 at 8:39:50 AM
Page generation time: 3.9844
