Forums >> Revit Building >> Technical Support >> Changing wall based family to non wall based?
Thu, Jul 10, 2008 at 1:57:16 PM | Changing wall based family to non wall based?
tebeane
I have a diaper changing station family (from the RevitCity site) that is wall based and I want to attach it to a toilet partition (which is not a wall). Is there a way to change this so it will attach to something otherthan a wall?
Thu, Jul 10, 2008 at 4:41:12 PM | Changing wall based family to non wall based?
You will have to build a new family that is face based.  You should be able to copy from one family to the other.
Tue, Nov 9, 2010 at 4:21:10 PM | Changing wall based family to non wall based?
skromer
Really this is the only way?  I'm having trouble copying, can anyone provide any more direction?
Wed, Nov 10, 2010 at 7:18:22 AM | Changing wall based family to non wall based?
You will have to start your new family adding reference planes and parameters to match the other.  Then, you will probabl;y only be able to copy sketches of the solids.  The solids themselves will not transfer.   Just have the two families open side by side in tiled views.
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:37 PM
Revit 2013 family from wall based to flor based
Mon, Feb 4, 2013 at 6:56:51 AM
Is it possible to make a line-based family wall based?
Wed, Jan 5, 2011 at 1:00:21 PM
Wall based family sinks into the wall
Fri, Aug 5, 2022 at 1:50:39 PM
Line Based Wall Rebate Family Question ?
Fri, Mar 28, 2014 at 1:18:48 PM
Page generation time: 2.0287
