12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Revit 2009 Wall finish wrapping around columns
45 Posts No Rating |
Hi all. I want to know: I draw columns that are round, concrete columns. Then I added walls. My question is, when a wall goes across a columns, the wall finish wrap around the columns. Is there a way to avoid that, I mean drawing a wall that goes across a column without the finishes layers wrapping? Thanks to all! Math.
Use a structural round column. The REVIT base column is areally a pilaster and it assumes the finish of the wall it touches.
Thanks! Is there a way to make the slab structural in Revit architecture 2009? Merci!
Wall finish wrapping at two different walls that intersect |
Thu, Mar 6, 2014 at 8:47:24 AM
Walls and Structural Beams/Columns and Finishes |
Tue, Jul 19, 2016 at 3:46:11 PM
12
wrapping wall materials |
Thu, Aug 14, 2008 at 4:40:22 PM
Problem with intersections between slabs(with finish)and columns |
Fri, Dec 28, 2012 at 11:31:58 AM
Wall wraping in windows and structural columns |
Mon, Feb 2, 2015 at 11:58:44 PM
