Forums >> Revit Building >> Technical Support >> Schedule columns coordinates
Thu, Jul 10, 2008 at 3:30:29 AM | Schedule columns coordinates
christophercarlsson
Hi!
 I'm wondering if it's possible to retrieve columns coordinates and then list them
in a schedule table?
Thanks
 /Christopher
Thu, Jul 10, 2008 at 3:47:51 AM | Schedule columns coordinates
christophercarlsson
Sorry, RAC 2008
/Christopher
Thu, Jul 10, 2008 at 7:20:36 AM | Schedule columns coordinates
KingRevit
4 Stars: 12 Votes
don't think that can be done.
you can use the spot coordinate to show their position put i think thats about it.
Fri, Dec 10, 2010 at 5:58:32 PM | Schedule columns coordinates
kbeegles
Anyone know if this is possible in 2011?
The Leffler Group
Sat, Dec 11, 2010 at 7:08:21 AM | Schedule columns coordinates
I believe you can schedule their grid location if those are the coordinates you are asking about.
Wed, Dec 15, 2010 at 9:10:32 AM | Schedule columns coordinates
kbeegles
Right, I forgot about that.  However, I do need their XY locations for our schedule.  Can anyone think of a way to use a formula with the grid locations in order to get those?
The Leffler Group
Wed, Dec 15, 2010 at 10:19:36 AM | Schedule columns coordinates
lunchtrayrider
3.5 Stars: 7 Votes
i'm just throwing this out there, but maybe you could use reporting parameters and then drag a marker point in each of the columns to a zero,zero location.  just an idea, no clue if it would work.
Wed, Dec 15, 2010 at 11:15:25 AM | Schedule columns coordinates
kbeegles
Excellent idea.  I'm giving it a shot right now, but it doesn't appear to be working quite yet.  I can drag the "origin" symbol to any point, but the column location (in my case it is a pile) is moving with it.  I've attached the family....could you take a look and see if you see anything I'm doing wrong?  Thanks.
The Leffler Group
Wed, Dec 15, 2010 at 8:45:11 PM | Schedule columns coordinates
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
How about
Unhide the origin (proyect base point) on the level you need
then go to anotate/spot coordinate and spot the center of the column
tip: you have to make a tiny simbolic line on the column family, you can use a L shape, and spot the vertex of the L.
In rac 2008 i dont know of you have that spot coordinate feature
pd: im checking the family you upload, its not working properly in elevation :S
Thu, Dec 16, 2010 at 4:51:03 AM | Schedule columns coordinates
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This would be possible using adaptive components, making it a 2 pick placement.  1st point locates the origin and the second sets the actual location.  You could then have two reporting parameters defining the offsets.  However, personally it sounds like a quite API job to me, or as others have stated using spot coordinates.  To me the information seems somewhat redundant anyway.
We will typically only locate two Set out points with spot coordinates then all the grids are set off these.  Columns would be set off the grids which they do by default...
Regards,
Chris.
Thu, Dec 16, 2010 at 9:15:19 AM | Schedule columns coordinates
kbeegles
I'm not sure where everyone else is coming from on this, but for us it stems from the need for a driven steel pile schedule that contains all of the pertinent info for each pile (size, embedded depth, elevation at cut-off, x and y coordinates).  With columns, we do place columns on grids wherever possible and then dimension the off-grid instances.  Unfortunately, the construction industry is driving the need for these coordinates located in a schedule and they aren't in any hurry to change the way they do things.
I downloaded the Exitech tool for generating coordinate parameters and it seems to be working great.  The only issue I have with it is that you need to run it every time any of the locations change.  It seems like it should be able to keep the information updated in real-time.
The Leffler Group
Tue, Dec 21, 2010 at 1:52:58 PM | Schedule columns coordinates
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The API on very recently enabled you to run background tasks when the system is idle...  So maybe they might be able to come up with a realtime solution soon?
Regards,
Chris.
Using Client's Coordinates and Scheduling Columns To Show Locations
Tue, Jun 7, 2016 at 2:50:40 PM
Reversing Grid naming of columns?
Mon, Nov 7, 2011 at 9:32:57 AM
List of coordinates
Fri, Aug 24, 2007 at 11:55:35 AM
text in Graphical schedule columns to far from lines
Thu, Dec 16, 2010 at 12:58:21 PM
Exporting Coordinates of Elements (Foundations, Columns, Points) to .txt or .csv
Fri, Jun 13, 2014 at 9:54:21 AM
Page generation time: 1.6797
