15 Users Online (13 Members):
Forums >> Revit Structure >> Technical Support >> Coordination points not working
5 Posts No Rating |
We have a revit model that we built using a dwg underlay. It gave lots of errors coming in but finally did go in (several months ago). As we've progressed we needed to link in more autocad / revit projects but the coordination points aren't lining up. I've gone through every tutorial I can find and it hasn't helped. Our reseller couldn't get them to work either, but using a new file they worked fine. We tried binding the project into a new file, but that created more problems than it solved. Does anyone have an idea for fixing the coordination points?
Product name: AutoCAD Revit Architecture Suite 2009Product version: 2009.0.0Product service pack: Web Update 3 Service Pack |
I'm afraid it's hard to tell what exactly we're helping with. What are the errors you are getting? Are the links moving around everytime you make a change? Are the links not loading in when you make a change? Help us help you! :D
5 Posts No Rating |
I'll give you anything you need, just let me know what you want! Yes, the links move around if they get reloaded. Also, when you link a new dwg or revit file, they come in all over the place. There are no errors when it comes in or is reloaded, just an incorrect placement. I've tried re-aquiring the point from a file, but it usually tells me everything is already placed there and there is nothing to move. . .
It sounds as if you are using the Center-to-Center option when linking models and DWGs in. When you link DWGs, if you have it aligned to origina, be sure you are using the Origin-to-origin option in the link/import dialogue. If you are using shared coordinates when linking Revit models, be sure you use the Shared Coordinates option in the link dialogue. Are you doing this already?
1 Posts No Rating |
Hi That is great, That is awesome information, i was also looking for this.Regards
michaeljee9 |
Working with Coordination models |
Wed, Apr 8, 2020 at 11:01:18 AM
BIM coordination role |
Tue, Apr 9, 2013 at 4:58:33 PM
Topographic points |
Thu, Nov 27, 2008 at 9:22:44 PM
Revit 2018 - Coordination Models and Printing to Vector |
Fri, Apr 21, 2017 at 2:49:50 PM
Possible to place contour lines to toposurface instead of points? |
Fri, Jun 1, 2018 at 2:57:52 PM
