Forums >> Revit Building >> Technical Support >> Project orientation
Wed, Jul 9, 2008 at 9:30:48 AM | Project orientation
Bhanu
Bhanu Avatar
Hello All,
We are starting a hotel project in Revit Architecture.
MEP & Structural teams would be working with AutoCAD only. I am trying to set up Rivet in order to get achieve the exact location and ucs of AuoCAD drawings.
Currently the entire site is rotated at an angle with north position, so AutoCAD drawings look inclined. As we all know that work around with UCS in AutoCAD gives us the convinient drawing positions.
In Revit I generally rotate true north angle and subsequent view would be aligned with true north. When individual buildings seperated need to be rotated use the view rotate option.
Am I making the issue clear ?
Are there any other ways to make this process more simpler. I would like to understand more about this orientation issues.
Thanks and regards,
Edited on: Wed, Jul 9, 2008 at 9:33:15 AM
Bhanu Gejjala,
VP - Project Architecture & BIM,
RSP , Dubai
Fri, Jul 11, 2008 at 2:57:49 PM | Project orientation
rkitect
rkitect Avatar
4 Stars: 29 Votes
What you want to do is start your revit model from a new project (assuming you haven't started it yet).  Make the view rotation True North and rotate the project however many degrees it needs to be rotated like you normally would.
Import the attached file into the view making sure you have Origin-to-Origin set as the orientation option.  This file will have a cross hair at the 0,0 mark of the model.  When you load in subsequent cad files, you need to be sure you use origin-to-origin so that they line up to this point.
You can set the view back to Project North when you're done to make modelling easier.
HTH,
North Point and project orientation
Wed, Nov 17, 2010 at 12:38:54 PM
3D View orientation won't lock
Sun, Feb 26, 2012 at 7:44:07 PM
Functionality Bugs
Workflow & Implementation >> Chameleon
Mon, Oct 15, 2012 at 5:55:48 AM
Missing Orientation option (Project North/True North) in Properties Palette
Fri, Jan 29, 2016 at 11:23:52 AM
Linked Revit model not importing in the correct orientation
Fri, Nov 20, 2015 at 4:00:35 AM
Page generation time: 0.5154
