Forums >> Revit Structure >> Technical Support >> Level Constraints
Wed, Jul 9, 2008 at 8:35:13 AM | Level Constraints
Allan1983a
I have created a roof and stipulated both Eaves and Apex of the roof, i now wish to change one of them whilst leaving the other the same, everytime i do this it changes both levels, is there a way around this~??????
Wed, Jul 9, 2008 at 11:45:40 AM | Level Constraints
emgeeo
3.5 Stars: 7 Votes
I'm not sure I understand what you are saying.
You've created levels for the apex and eaves?  One level for the apex- one level for the eaves?  And when you change the elevation of the apex level the eaves level changes too?
I'm assuming you are creating a level for your apex and a level for your eaves.  Is that correct?
Wed, Jul 9, 2008 at 11:58:42 AM | Level Constraints
Allan1983a
yes thats it! one level for each which then ties them together, im in Revit 2009 and think ive just solved it!!! thanks!
Changing model constraints from one level to another
Wed, Aug 12, 2015 at 3:29:36 PM
Wall Constraints invalid
Fri, Sep 22, 2017 at 3:41:44 AM
13
Revit 8.1 - Already problems with base and top constraints
Fri, Jan 13, 2006 at 11:58:40 AM
Family Instant Parameter Constraints Offset
Fri, Feb 1, 2013 at 2:41:00 PM
Reasigning associated level/base & top constraints on a masive model
Thu, Oct 11, 2012 at 12:51:30 PM
Page generation time: 2.7814
