Forums >> Revit Building >> Technical Support >> Creating a Sheet within a Family File
Wed, Jul 9, 2008 at 1:14:33 AM | Creating a Sheet within a Family File
syoung
Revit 2009
It seems that there is no way to Load a Sheet into a Family?
I am wanting to draw up some manufacturing drawings of a benchtop but can't seem to load a sheet.
Do we seriously have to load this family into a new project and do it all there? Or have I missed something...
thanks,Simon.
Wed, Jul 9, 2008 at 2:10:49 AM | Creating a Sheet within a Family File
Elmo
3.5 Stars: 4 Votes
On sheets right click and say and add a sheet. If you don't have titleblock you wont be able to create a sheet. You will need to load a titleblock into your project and then you should be able to drag and drop a view onto your sheet.
Wed, Jul 9, 2008 at 3:38:12 AM | Creating a Sheet within a Family File
KingRevit
4 Stars: 12 Votes
syoung you are right you can't load a sheet into a family, you will have to load the individual parts of the family into a project to get your manafacturing drawing, remember revit is primarily an arcitectural tool. but the legend tool may help.
creating sheet frame using dwg file
Tue, Nov 1, 2005 at 11:35:09 AM
Creating Sketch Sheets and linking revision tags to Original sheet...
Fri, Jul 14, 2017 at 11:16:31 AM
14
Auto Sheet Number Extraction while Creating a PDF.
Mon, Oct 10, 2016 at 10:01:26 AM
How to save family drawings to pdf file?
Thu, Aug 25, 2016 at 11:46:26 AM
Creating Custom Sheet Family Trouble
Wed, Mar 21, 2012 at 9:28:45 AM
Page generation time: 2.7055
