13 Users Online (11 Members):
Forums >> Revit Structure >> Technical Support >> REVIT PROMPT: Would you like walls to attatch to this floor's bottom?
I'm sure we have all been prompted to decide whether we want walls to attatch to a floor's bottom. My question is can you reverse this once you've decided to allow this to happen. Sometimes having walls extend to a floor's bottom is helpfull (as in the case for interior partitions. When you are modeling a building shell with walls that span multiple floors you may not want this. Is there a way to undue this option globally?
Edit the floor and move an edgs slightly so that it is changed, then answer no to this question.
3 Posts No Rating |
Is there a way to disable this prompt?
No, I don't believe there is but a simple click gets you past it.
Showing walls from the bottom of slab |
Tue, Feb 9, 2010 at 10:40:40 AM
Ground Floor info. appearing on Second Floor |
Thu, Jun 9, 2016 at 2:24:40 PM
Sloped floor but flat bottom |
Wed, May 16, 2012 at 2:52:55 PM
Walls in Framing Plan |
Fri, Dec 21, 2012 at 1:08:42 PM
Joining Walls to Floor |
Thu, Jun 18, 2015 at 8:36:23 PM
