Forums >> Revit Systems >> Tips & Tricks >> Wall sweeps & profiles
Tue, Jul 8, 2008 at 11:59:36 AM | Wall sweeps & profiles
tinninttu
I created new profiles for a screen porch, how do i load them into the project as wall sweeps and apply them to my wall that i have created.  i created a base trim, a mid rail and headers as well as lattice work that will cap it all off.
thanks
 stephanie
Wed, Jul 9, 2008 at 4:22:01 AM | Wall sweeps & profiles
Dafpfy
3.5 Stars: 11 Votes
you can do this in two ways,
 1e , add the sweep into the wall itself, go to edit wall , edit structure, ( make sure the preview is set to section )
and add in your profile ( s )
2e
load your profiles into your project and go to the modeling tab , host sweeps , wall sweeps, and make a new sweep with you profiles , this way you can add your sweeps to any wall any time, this is the most easy way i think,
gl
Kind regards,
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Tue, Jul 15, 2008 at 10:52:39 AM | Wall sweeps & profiles
niranjan
hi this is niranjan... i saw ur question.... i think you can do this by modelling ----> create option..... there u can load this profile.... i am not sure.....
wall sweeps
Fri, Sep 12, 2008 at 5:49:17 AM
wall sweeps
Mon, Dec 29, 2008 at 5:20:42 PM
Wall sweeps
Wed, Jul 8, 2009 at 12:19:56 PM
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Wall sweeps / mitering
Sat, Jan 31, 2009 at 4:26:09 PM
Page generation time: 0.6893
