Forums >> Community >> Newbies >> Door tag font size
Tue, Jul 8, 2008 at 3:10:28 AM | Door tag font size
mate
How do I change the font size of (all) my door tags/labels...?
Tue, Jul 8, 2008 at 4:33:28 AM | Door tag font size
Dafpfy
3.5 Stars: 11 Votes
change the doortag family
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Tue, Jul 8, 2008 at 4:37:50 AM | Door tag font size
mate
Well, there is no door tag family with a small enought font.
So let me refrase: How do I change the font size of the door tag family...?
Tue, Jul 8, 2008 at 4:39:47 AM | Door tag font size
Dafpfy
3.5 Stars: 11 Votes
like i see it you can make it 0.0001 mm small is this to big?
peace is the path."
Mahatma Gandhi.
Tue, Jul 8, 2008 at 4:54:53 AM | Door tag font size
mate
Of course not, but I still have not found out how to change the font size of a door tag family (or create a new family with a different size).
The font size of the families I can find are too big.
Tue, Jul 8, 2008 at 4:59:10 AM | Door tag font size
Dafpfy
3.5 Stars: 11 Votes
select the text label in your doortag family and go to properties, edit , text size,
Edited on: Tue, Jul 8, 2008 at 4:59:37 AM
peace is the path."
Mahatma Gandhi.
Tue, Jul 8, 2008 at 6:11:32 AM | Door tag font size
mate
My question has HOW do I "make it 0.0001 mm"?
I solved it by opening a door tag family file (rfa), change the font size and then use the modified family for the project...
Tue, Jul 8, 2008 at 7:15:22 AM | Door tag font size
Gee ... that's what I thought they told you to do .... go figure!
Tue, Jul 8, 2008 at 7:37:23 AM | Door tag font size
Dafpfy
3.5 Stars: 11 Votes
^^ lol WWHub, luckely this is under newbies forumtab Smile
peace is the path."
Mahatma Gandhi.
Sat, Aug 6, 2011 at 7:29:26 PM | Door tag font size
natureboyms
Here is a step by step guide, for Revit 2011:
1. Select a door tag.  The "Modify" tab will highlight green and change to "Modify|Door Tags".
2. Select "Edit Family" under the green tab.  The family file will open.  It is a separate file outside of the project file.
3. Select the label itself, not the borders (which are lines).  The Modify tab now changes to "Modify|Label".
4. Oddly enough, you do not select "Edit Label" under the "Modify|Label" tab.  Rather, select the "Edit Type" button under the properties box.  Pay close attention to what you are choosing, else confusion will ensue.  A dialogue box will open when you select "Edit Type".
5. Now you can change the font size of the tag itself, next to "Text Size".
6. Once you've got it like you want it, hit the "Load into Project" button under the "Modify" tab.
The main lesson to learn from this exercise is what changes you can make by either clicking "Edit Type" or "Edit Label".  They each allow a different set of changes.
Door tag switches visibility parameter automatically
Wed, Nov 17, 2010 at 8:17:46 PM
Residential Door Tag
Fri, Jul 7, 2006 at 8:18:54 PM
door tag exposing the door-width
Wed, Sep 16, 2009 at 4:52:04 PM
Parameter Formula Help Needed
Thu, Oct 15, 2009 at 8:38:22 AM
Door tag placement??
Thu, Jun 8, 2006 at 11:44:11 PM
Page generation time: 5.5159
