12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Lines Length or Moving a Line less than 1/32"
10 Posts No Rating |
I use Revit Arch 2009 and if I try to move a line less than 1/32" I get this error "Element is to small on screen". This cause problems when trying to align instances and they are less than 1/32" apart. I get the same error if I try to draw a line less than 1/32", the symbol of a circle with a line through it appears. Help, I have to do a lot of aligning and I have had to move the instance away futher than 1/32" and then move it back again to get the alignment correct. I hate doing things twice that I should be able to do in one move. Thanks The Cadpounder
the 1/32" is a limitataion of Revit. i don't any other way aroundit other than what you are doing. ???
Moving topography lines that appear in elevation down 6" |
Mon, Jul 7, 2014 at 11:11:03 AM
Parametric Line Extension...array or repeating line or...? |
Mon, Jul 2, 2012 at 3:30:38 PM
line based family help (length) |
Wed, Aug 6, 2014 at 9:15:36 AM
Any Suggestions For Line wt Table set up and Line Style Names |
Thu, Jun 5, 2008 at 7:01:45 AM
Measurement of detail lines |
Tue, Sep 2, 2008 at 2:46:13 PM
