Forums >> Revit Building >> Technical Support >> Hide View Name in Elevation Tag
Mon, Jul 7, 2008 at 12:24:40 PM | Hide View Name in Elevation Tag
everist
3 Stars: 2 Votes
On version 2009 is there a way to hide the view name that appears by default in the circular elevation tag? I did not experience this problem in version 2008.
Mon, Jul 7, 2008 at 12:51:32 PM | Hide View Name in Elevation Tag
rkitect
rkitect Avatar
4 Stars: 29 Votes
By accessing the Elevation Tag type properties dialogie, you can modify this parameter:
Settings > View Tags > Elevation Tags
-Choose the 1/2' Circle (or create a new type)
-Uncheck the "Show view name" parameter
-Hit ok till you're back at the canvas, view names should be gone now.
HTH
Wed, May 20, 2009 at 2:56:50 PM | Hide View Name in Elevation Tag
MDAdave1999
What if I uncheck it now and still shows the "elevation" text to the side?  Thanks
Wed, May 20, 2009 at 2:57:53 PM | Hide View Name in Elevation Tag
MDAdave1999
I just figured it out, thanks
Wed, May 20, 2009 at 3:36:38 PM | Hide View Name in Elevation Tag
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Please, try to post your own responses, so others can learn too......
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Multi-view Elevation - Reference SIM
Fri, Mar 9, 2012 at 8:40:42 AM
One elevation tag / two pointer directions / one drafting view
Wed, Dec 18, 2013 at 8:58:33 AM
Elevation View for Window Schedule Not Dimensioning
Fri, Sep 12, 2008 at 3:01:09 AM
My dependant elevation view tag will not show up in my dependant plan view
Tue, Jan 8, 2008 at 11:47:57 AM
Page generation time: 0.7541
