Forums >> Revit Building >> Technical Support >> Array Formula error
Thu, Jul 3, 2008 at 5:17:39 PM | Array Formula error
BrettoH75
ok i think there could be a bit of a qlitch here im using RA2009 and i know i have done this before but here goes i could be going crazy.
Array family with simple formula ( Parameter(length) / Parameter(integer) Winking -54mm
Now i get the answer calculated in the value field but when i hit apply i get the following error message
                                          "Can't find solution for formulas for Type ' '."
I have removed the parameter twice and redone it as well as changed the parameter type with still the same responce any ideas.
Brett
Brett
Thu, Jul 3, 2008 at 5:23:08 PM | Array Formula error
BrettoH75
ok dont worry i found the solution - add the parameter at the array creation stage.
It seems you cant use a parameter created before the act in this situation? go figure
Brett
Array formula (9.1)
Mon, Sep 24, 2007 at 7:12:47 PM
Family w/ Array Formula
Fri, Mar 23, 2007 at 9:29:37 AM
Variable Length Family with Array Formula
Wed, Aug 8, 2012 at 9:56:46 AM
Array Formula
Tue, Dec 9, 2008 at 11:11:51 AM
Array Formula Problems
Tue, Jul 26, 2011 at 2:30:54 AM
Page generation time: 0.4532
