15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Volume formula issues
OK - Im a total formual Newbe What I am trying to do is generate a volume formula within my family. I have set the following attributes Shelf Volume Shelf Width Shelf Depth Shelf Spacing Shelf Thickness Bracket Height therfore my formula is LxDxH(which I cant get working) Shelf Volume = (Shelf Width * Shelf Depth) * (Shelf Spacing - Shelf Thickness - Bracket Height) * 4 As there are 4 shelves I add the * 4 at the end. Can some1 tell me what I am doing wrong??? I wish there was dumb down instructions for formulas :| Edited on: Wed, Jul 2, 2008 at 11:08:32 PM
Edited on: Wed, Jul 2, 2008 at 11:08:58 PM
Are you getting an error or is the number that you are getting DEFINITELY not the correct answer? Also, I'm guessing the Shelf Volume parameter is the total volume of all the shelves of the family combined? Are the shelves uniform or is each shelf a different width/depth/thickness? If they are uniform wouldn't it be easier to do (Shelf Width * Shelf Depth * Shelf Thickness) * No of Shelves ?
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
Im more after the merchandising volume calculation
Anyone??????
I see now, you're looking for the total volume of empty space between the shelves. That makes more sense than calculating the total volume of the shelves themselves. :D If you have a parameter for your side, top and bottom pieces the could befairly painless: ((Height-(Header Height-Footer Height))*(Width-(2*Side Thickness))*(Depth-Back Thickness))-(No of Shelves*(Vol of Shelves) Make sense?
Edited on: Mon, Jul 7, 2008 at 8:44:24 AM
Column Volume in Tag |
Tue, Oct 4, 2011 at 1:53:31 PM
Creating a wall tag with a volume parameter |
Sun, Jun 23, 2013 at 3:56:03 PM
Calculating Volume |
Tue, Sep 4, 2007 at 2:35:09 AM
Taking off material volume |
Wed, Feb 22, 2012 at 4:08:50 AM
conc volume |
Mon, Apr 11, 2011 at 9:21:01 AM
