Forums >> Revit Building >> Technical Support >> Model pattern troubles
Wed, Jul 2, 2008 at 4:18:27 PM | Model pattern troubles
revitdevil
revitdevil Avatar
Not sure why this is happening, but I need to figure it out.  I have a specific floor on several floors of my model in different views.  In one of the views the floor has a model pattern on it.  It only shows up in this one view, and it hasn't been overriden.  When you open the element properties of the floor it shows there is no surface pattern on the floor.  I can't think of anything else it could be.  The structure of the floor shows no surface patter as well.  Any ideas?
Thu, Jul 3, 2008 at 7:42:36 AM | Model pattern troubles
Is it possible that someone "poured" a new finish on this floor using the paint bucket.  You can "pour" the correct finish back on the floor if they did.
Thu, Jul 3, 2008 at 10:29:15 AM | Model pattern troubles
revitdevil
revitdevil Avatar
GENIUS!!! That worked like a charm. I should have know that.
Thanks for your help
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:11:59 PM
Question About Model Pattern
Tue, Feb 19, 2013 at 2:40:21 PM
Model pattern override
Wed, Nov 10, 2010 at 3:50:54 PM
Model Cut Pattern?
Wed, Jan 30, 2013 at 12:16:11 AM
Editing Model Patterns...
Mon, Jan 4, 2010 at 12:56:50 PM
Page generation time: 2.2483
