Forums >> Revit Building >> Technical Support >> Floor hosted family?!
Wed, Jul 2, 2008 at 10:37:45 AM | Floor hosted family?!
psemrau
I'm doing a floor hosted family using the floor hosted family template. It workd well for some of my family types, but it has a floor opening in it, for a specific type it grows beyond the edge of the generic floor and it gives me all sorts of errors.
The template has a generic floor mass in it, that is too small!!! I do not see any <edit> button or anything, even the size properties are locked!
Is there a way of growing/scaling/streching it?
Wed, Jul 2, 2008 at 2:27:55 PM | Floor hosted family?!
TABEST
4 Stars: 4 Votes
Your opening is allowed to exceed the floor, the floor is just in there so that you can "see" what you are doing.  If you are having problems with a particular type, try the following, when making your parametric families, make reference planes first, dimension them, do their parameters, etc.  then "flex" your model, ensuring it behaves properly.  Once it works right, then add in reference lines (if you need them) or model/symbolic lines/geometry.  The number one error that I find where I'm working is that users constrain something to the "flesh" of the model (geometry, lines, etc.) instead of the "bones" (ref planes, ref lines).  Using my analogy above, if you try to "flex" the model, if it is dimensioned to the "flesh" then it might rip off.  If dimensioned to the "bones" it will produce an "error" if it can't be flexed in that manner, but won't be "ripped" off.  Hope this helps.
Wed, Jul 2, 2008 at 2:36:11 PM | Floor hosted family?!
psemrau
Well, I created the family that way, using parameters attached to reference planes and then attaching all the solids and openings to them. (Must have screwed it somewhere).
Let me try your method using a blank template and test it for weirdness...
thanks.
Wed, Jul 2, 2008 at 4:51:09 PM | Floor hosted family?!
psemrau
Thanks,
I revised my family -like you said- and it had 2 symbolic lines attached to objects instead of reference planes (they were overlapping). Fixed that
I got the <Opening is not cutting anything> error, but just ignored it...
Worked perfectly!
Wed, Jul 2, 2008 at 5:56:49 PM | Floor hosted family?!
TABEST
4 Stars: 4 Votes
glad to hear it
Floor hosted family to not be hosted by floor
Tue, Dec 23, 2008 at 6:47:16 PM
Floor with Valleys and Ridges - Hosted Components Won't Slope
Thu, Oct 28, 2010 at 2:01:36 PM
How would you modify a family from face-based or hosted to one that is not?
Mon, Sep 26, 2011 at 8:39:50 AM
Floor Hosted Families on a Sloped Floor
Wed, Jun 4, 2008 at 7:31:21 AM
Floor hosted Casework family will not place on floor
Mon, Apr 26, 2010 at 10:28:29 AM
Page generation time: 1.1355
