Forums >> Revit Building >> Technical Support >> Filter walls by floor level or base constraint??
Tue, Jul 1, 2008 at 5:31:01 PM | Filter walls by floor level or base constraint??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Is there anyway to apply a filter to walls on a specific level or base constraint?  Or even height?
Any help would be appreciated.  Thanks,
Lorne
Denver, CO
Revit Architecture
Wed, Jul 2, 2008 at 9:10:55 AM | Filter walls by floor level or base constraint??
ahocutt
I create a new text parameter and name it mark, building, level, or whatever you want to be able to filter it by.  for levels, it easy to use and elevation view, select all the wall in that level, type in what level they are, and then filter it out, or filter the other levels out.
Wed, Jul 2, 2008 at 9:58:20 AM | Filter walls by floor level or base constraint??
lunchtrayrider
3.5 Stars: 7 Votes
lorne are you talking about selecting and ahocutt are you talking about scheduling?
Sat, Jun 8, 2013 at 9:25:24 PM | Filter walls by floor level or base constraint??
no7playground
I meet the same problem when I am working on the 4D model by Navisworks and Revit, I found a way, it is very effiecient but bears some malfunction. For each level-stuff you want to select, you can set the View Range just as the same as the height of the level and then select by filter, most of the stuff are the ones on the very level(with some exceptions that some objects go throungh several levels).
Thanks!
No7playground
demo wall schedule "by floor"
Fri, Apr 1, 2005 at 1:43:15 AM
Walls show up on Second Level plan
Wed, Dec 19, 2018 at 8:39:24 AM
Level Consraint on a room.
Thu, Jul 30, 2009 at 1:52:00 AM
top/base constraint as a parameter in family types
Wed, Sep 9, 2009 at 4:49:38 PM
Overhead wall and Level 3 are not aligned
Thu, Mar 17, 2016 at 10:17:42 AM
Page generation time: 0.6700
