Forums >> Revit Building >> Technical Support >> GeodesicDome and space frame
Tue, Apr 12, 2005 at 12:35:49 AM | GeodesicDome and space frame
cpbc
3.5 Stars: 3 Votes
Hi guys! How to do a geodesic dome space frame with diamond shaped glass panel? The normal family creation only yields rectangular shaped glass panel.
Tue, Apr 12, 2005 at 12:51:55 AM | RE: GeodesicDome and space frame
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmmm, not currently possible AFAIK in any automatic way as you cannot rotate grids associated to a curved plane. One method would be to create a surface in another program that creates the desired faces to the shape desired then import that in and use it as mass to associate curtain walls to. Or create a family for the diamond piece with a slope then radial array 180º it at the varying angles. HTH
Tue, Apr 12, 2005 at 1:07:57 AM | RE: GeodesicDome and space frame
cpbc
3.5 Stars: 3 Votes
Thanks Mr Spot for your input. I understand that you are final year students in architecture. Maybe we can share our experinece.
Tue, Apr 12, 2005 at 1:37:39 AM | RE: GeodesicDome and space frame
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sure, email me if you like.
making space frame in revit.
Tue, Dec 21, 2004 at 5:15:38 PM
Sat, Apr 2, 2005 at 7:42:13 AM
Inner space is not surrounded by outer space with higher height.
Thu, Sep 6, 2012 at 8:34:57 AM
HoW CAN İ CUT A SPACE FRAME STRUCTURE ?
Mon, Jan 6, 2014 at 7:27:56 AM
Seperating steel frame ( NEED HELP)
Mon, Aug 15, 2016 at 10:38:37 AM
Page generation time: 1.9604
