Forums >> Revit Building >> Technical Support >> .ies file orientated wrong for tube light source
Tue, Jul 1, 2008 at 3:00:33 PM | .ies file orientated wrong for tube light source
kdummer
I am working on some cove lighting and downloaded the .ies photometric file from a manufacturer. I set up the light source definition shape as "line" and the light distribution as "photometric web".In the family type under photometrics I loaded the ies file from the web and entered the "emit from line length" as 6' the problem is that the 3d photometric web that is displayed is orientated wrong. It is 90 degrees off in relation to the "emit from line length". All I want to do is rotate the photmetric web 90 degrees in relation to the "emit from line" light source line. The problem is that when you select one and rotate it the other rotates as well. I have searched for possible constraints and even looked in the ies file itself to see if there is a way to rotate it 90 degrees before loading the file in the light source. I have not figured out how to do this... Please help.
Mon, Nov 17, 2008 at 2:00:26 PM | .ies file orientated wrong for tube light source
jlights
3 Stars: 2 Votes
I hear ya. Open the family, right click on the light source to get Element properties. Then edit the tilt angle as needed. If the tilt angle parameter is grayed out, select the little button to the right of the Tilt Angle parameter value. This opens up another dialog box where you can change the parameter from Angle to None. Then you can edit the tilt value in the original dialog box. Might take a few tries until you get it facing the way you expect it to face.
jlights
IES FILE AND LITGHT SOURCE NOT IN SAME DIRECTION
Mon, Feb 6, 2017 at 2:16:45 PM
IES Photometric lighting issue - no light
Thu, Aug 13, 2009 at 3:30:28 PM
Aligning IES with light fixture
Fri, Sep 12, 2014 at 10:17:59 AM
IES files in Revit
Mon, Feb 6, 2017 at 4:00:14 PM
Issues with Light Source in Revit 2013
Wed, Jun 5, 2013 at 2:48:23 PM
Page generation time: 3.1755
