Forums >> Revit Building >> Technical Support >> pat files
Tue, Jul 1, 2008 at 1:27:02 PM | pat files
hyoung001
I am trying to create a pattern file and i cant seem to do it. I followed the example given in the help but when i try to import i get an error that reads " 3rd line syntax error import aborted" does anyone know why this is happening?
Here is the file as it reads now
 *Slate Tile 16" x 24".
;%MODEL.
45, 0, 0, 12, 36, 36, 12
45, -12, 12, 12, 36, 36, 12
-45, -12, 36, 12, 36, 24, 12
-45, -12  48, 12, 36, 24, 12
Any info would be of great help.
Wed, Jul 2, 2008 at 2:42:11 PM | pat files
TABEST
4 Stars: 4 Votes
try changing your 12 at the end to -12.  They way I view the numbers is as follows:
angle, x offset, y offset, shift (left or right), distance to next repeated line, and then how long to pick the pen up.
 I always have -# at the end of the line, and I think of this as the pen being picked up... It works for me, maybe it can for you...
Wed, Jul 2, 2008 at 2:49:50 PM | pat files
rkitect
rkitect Avatar
4 Stars: 29 Votes
try this:
;%TYPE=MODEL
-45, -12, 48, 12, 36, 24, 12
Here were your problems:
-You needed the %TYPE= in front of the pattern type.
-The last line, you were missing a ',' after the '-12'
After this I was able to import the pattern fine.
Edited on: Wed, Jul 2, 2008 at 2:50:34 PM
Pat Files
Thu, Jan 22, 2009 at 1:26:47 PM
looking for .pat files [ 1 2 ]
Tue, Dec 1, 2020 at 1:43:31 PM
24
Use Pat Files
Tue, Sep 1, 2009 at 4:18:40 AM
11
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder?
Mon, Jul 6, 2015 at 11:01:26 AM
custom pat files
Fri, Oct 21, 2005 at 3:13:23 PM
Page generation time: 0.1982
