9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Problems with Shadows in Revit 2009
6 Posts No Rating |
I have created a chimney pot family (not a very good one at that) and the shadows are incorrect (see image). I have tried removing the various cutouts and protrusions but the shadow does not change. I have used a stone as the material for appearance only. Any thoughts to why would be much appreciated, also can I turn off shadows for individual items (families) and are then any 'shadow options' when editing a family. Cheers Tim
This may be one you want to send to AutoDESK. Maybe if you post your family, someone else can help. As far as the controls - none in the family level and you can not turn off the shadow for individual elements as far as I know.
6 Posts No Rating |
thanks, looks like it doesn't like Solid Blends, or at least my solid blend. I have changed to a straight extrusion (with the same cutouts and additions) and the shadows are fine.
Thanks for reporting back what you discovered.
Shadows Inverted- light is gray/shadows are white |
Fri, Sep 25, 2009 at 4:46:09 AM
Shades in prospects |
Mon, May 4, 2009 at 9:58:57 PM
Shadow problems with ramps |
Fri, Jun 22, 2012 at 11:56:18 AM
RPC Shadows |
Tue, Jul 22, 2008 at 3:32:11 AM
Weird shadows created by pipe railings |
Tue, Apr 11, 2006 at 8:14:34 PM
