Forums >> Revit Building >> Technical Support >> Modifying the default tags
Mon, Jun 30, 2008 at 2:52:04 PM | Modifying the default tags
JDH2
Is there a way for me to modify the appearance of the Interior Elevation Tags?  I was able to change the appearance of the door tags by using the Edit Family command, but I am not able to modify the interior elevation tags by using the same concept.  Thanks in advance for you help on this one.
JDH2
Thu, Jul 3, 2008 at 11:30:18 AM | Modifying the default tags
rkitect
rkitect Avatar
4 Stars: 29 Votes
Unfortunately, elevation tags are not editable in appaerance.  This is an issue that has been fought for a LONG time with Revit and unfortunately has not had an opportunity to be addressed yet.  The workaround would be to make an annotation component that looks the way you want it to and hide the elevation tag that revit uses.
HTH.
Modifying Default Family Templates
Mon, Apr 26, 2010 at 2:20:23 PM
Structural Element Tags
Fri, Oct 3, 2008 at 11:27:10 AM
Adding default tags
Tue, May 15, 2007 at 12:35:35 PM
finding default shared paramaters
Sun, Feb 1, 2009 at 5:21:18 AM
Building Elevation Tags
Thu, Feb 17, 2011 at 9:32:02 AM
Page generation time: 0.4474
