Forums >> Revit Building >> Technical Support >> text on plans
Mon, Apr 11, 2005 at 4:02:40 PM | text on plans
ridhs
hii im having a bit of a problem with adding text to my dwgs. i have made a copy of my plans and when it copies the text, because i chane the scale of that particualr dwg the text appears too small. how can i get the text to automatically change accordin gto the scale of the dwg. also how do i get the text to wrap..as in if i increase the size of the text the box becomes bigger and sometimes it splits the letters and its quite annoying to have to go to each one and fix it. also one last thing with this wats the best way to get the text to align with each other, eg horizontally and vertically so the plans look neat and clean and u dont have ur text every where.. is there a way i can snap it or smthg?
Mon, Apr 11, 2005 at 8:42:11 PM | RE: text on plans
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Text size is the same print size regardless of view scale. Drag a window around the drawing to select all text (use the filter to only select text) then go to properties-->edit/new-->create a new text size or if you already have one setup for the size you want just change to that type. Text will automatically snap to text in the same view. Snap points depend on how the text is justified... HTH.
Placing Text "Floor PLans" or "Sheets"
Mon, May 16, 2011 at 4:35:08 PM
How can I make a new tag (with new text field on the label) for Area plans?
Thu, Jul 5, 2018 at 1:51:27 AM
Text Visibility
Tue, Sep 12, 2017 at 7:19:10 AM
Evacuation Plans
Thu, Sep 29, 2022 at 10:58:02 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Page generation time: 2.0009
