Forums >> Revit Building >> Technical Support >> Complex Roof (spaceframe)
Sun, Jun 29, 2008 at 10:48:10 PM | Complex Roof (spaceframe)
schuss
I am very new to Revit, and need to produce the roof system as shown in the CAD file attached.  The roof is basically made up of triangular panels, with most of the corners at different heights.  I have written the heights each corner needs to be Cryingin millimeters).
I have tried to set the model up as seperate panels using Roof By Footprint, and Slope Arrows, however I can only get the slope in one direction and not two.
I have also tried to set this up using wall sweeps, but just can't get it accurate enough, and I also need to work out the surface area of the panels.
 I'm using Revit Building 9.  Any help is appreciated.
Mon, Jun 30, 2008 at 12:24:53 AM | Complex Roof (spaceframe)
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey have a look at this tutorial:
http://www.revitcity.com/tutorials/complex_slabs/
If that doesnt help, model a flat roof, but model each panel individually. Then click on the roof, and you should see the icons in my picture (I use RAC2009, so I dont know if version 9 has this capability). Use these to individually change the height of each corner, and then your roof should be modelled correctly. Im not sure about surface area, but other things can be determined (just look at the element properties). I modelled it, and it turned out really well =)
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Mon, Jun 30, 2008 at 12:27:27 AM | Complex Roof (spaceframe)
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Mon, Jun 30, 2008 at 12:35:16 AM | Complex Roof (spaceframe)
timbo89
timbo89 Avatar
4 Stars: 5 Votes
ps an easy way to calculate surface area is by modelling the roof as a toposurface (again model each individual panel), and go to element properties, and surface area is displayed =)
Mon, Jun 30, 2008 at 1:21:00 AM | Complex Roof (spaceframe)
schuss
Thanks timbo.  Unfortunately in my version of Revit those buttons aren't shown.  I'll give the tutorial a go.
Mon, Jun 30, 2008 at 10:57:22 PM | Complex Roof (spaceframe)
schuss
The toposurface seems to work the best, however is it possible to give the material a thickness?
Mon, Jun 30, 2008 at 11:18:14 PM | Complex Roof (spaceframe)
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Unfortunately not. If you create the toposurface and the use the massing technique (as described in the tutorial), you can then create the roof by face, then the roofs thickness can be changed. I strongly suggest you upgrade the version of Revit you are using, because all features have been enhanced, and complex jobs can be easily modelled.
complex curved roof structure
Thu, Mar 12, 2009 at 1:11:49 PM
HOW TO CREATE SHED TYPE ROOF IN COMPLEX/TRAPEZOIDAL FLOOR PLAN
Fri, Sep 20, 2019 at 11:10:56 PM
complex roof
Mon, Jul 30, 2007 at 12:40:08 PM
Roof By Face Complex Roof
Thu, Apr 11, 2013 at 4:34:28 AM
Complex Roof
Mon, Dec 5, 2005 at 1:19:52 PM
13
Page generation time: 0.2455
