Forums >> Community >> Newbies >> How much detail should one put into a model?
Sat, Jun 28, 2008 at 5:22:14 PM | How much detail should one put into a model?
treeves68
Ive been running Revit at home now fro 3 months or so. I get better and better every day. My question is how much detail should one model into their model? What I mean is should I be using floor slabs for floors instead of trying to actually model the actual framing? Same for roofs, should I just use roof slabs instead of actually putting in trusses and so forth? I guess I could easily just use the slabs...then when I do my sections and details just detail those particular views instead of the entire model. Whats the standard way that it should be done? How is everyone else doing it?
Sun, Jun 29, 2008 at 7:36:32 AM | How much detail should one put into a model?
4 Stars: 205 Votes
Hi, i think you must work in revit like do you want, if you want to put the trusses and the roof slab in model when you cut the model by the sections you have the work done, you don't need to put them in the details view....
Mon, Jul 28, 2008 at 6:15:12 PM | How much detail should one put into a model?
cganiere
cganiere Avatar
Decide what you want the model to do.
1) generally show the construction and use details for the specifics.
2) use enough detail in the model to just use call outs for the details.
3) show everything visible for a photorealistic rendering.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
2D detail locked to 3D model
Fri, Nov 3, 2006 at 5:49:02 PM
Detail Family Line weight sub-catoagories gone when family put into project
Tue, Aug 30, 2016 at 6:52:17 AM
11
Detail References
Wed, Apr 19, 2006 at 6:18:57 PM
Attached detail groups missing from model groups...
Mon, Aug 17, 2009 at 8:11:10 AM
Page generation time: 1.2647
