Forums >> Revit Building >> Technical Support >> Lost Blue Handles
Fri, Jun 27, 2008 at 2:55:16 PM | Lost Blue Handles
mhans
3 Stars: 10 Votes
Hi,
What causes me to loose those blue handles (drag/clip adjustment) on some of my enlarged plans? Thanks.
Motto: "No Post left behind"
Fri, Jun 27, 2008 at 3:07:39 PM | Lost Blue Handles
lunchtrayrider
3.5 Stars: 7 Votes
on walls?
I like scooters. and motorcycles.
Fri, Jun 27, 2008 at 3:17:57 PM | Lost Blue Handles
mhans
3 Stars: 10 Votes
Here's what I mean. In some cases, I can't find those drag handles on plan. If I start a new project, it shows. In the project that I'm now doing, sometimes I see, sometimes I dont.
Fri, Jun 27, 2008 at 3:23:08 PM | Lost Blue Handles
lunchtrayrider
3.5 Stars: 7 Votes
well to get the blue dots on the end you have to turn on the crop view in that elevation.
Fri, Jun 27, 2008 at 3:24:15 PM | Lost Blue Handles
lunchtrayrider
3.5 Stars: 7 Votes
for the other half I'm not sure why you can't see them other then they aren't where you think they are.
Fri, Jun 27, 2008 at 3:26:36 PM | Lost Blue Handles
lunchtrayrider
3.5 Stars: 7 Votes
dup'ed
Edited on: Fri, Jun 27, 2008 at 3:27:04 PM
Fri, Jun 27, 2008 at 3:34:23 PM | Lost Blue Handles
mhans
3 Stars: 10 Votes
Here's another screenshot of a roomin the same project I'm working on. THanks
Mon, Jun 30, 2008 at 11:20:42 AM | Lost Blue Handles
lunchtrayrider
3.5 Stars: 7 Votes
bump
Mon, Jun 30, 2008 at 12:38:50 PM | Lost Blue Handles
mhans
3 Stars: 10 Votes
Oops. Sorry, no image. Try again.
Mon, Jun 30, 2008 at 12:49:38 PM | Lost Blue Handles
emgeeo
3.5 Stars: 7 Votes
If you are talking specifically about view-handles...
the 'far clip offset' option in the element properties box controls the depth of your view- I've sometimes seen this default to stagering depths...mostly in callouts...but don't know why.
Mon, Jun 30, 2008 at 12:50:45 PM | Lost Blue Handles
#11
lunchtrayrider
3.5 Stars: 7 Votes
you have an associated datum.  I don't know what this is used for (i should probably know, i should f1 it and find out) but once you set it from none to anything then that line goes away.  then things may work funny afterwards.
Mon, Jun 30, 2008 at 1:05:54 PM | Lost Blue Handles
#12
mhans
3 Stars: 10 Votes
I don't know about that Associated Datum where it came from. I change it to None and found my blue handle along grid 18. I tried to drag it back into the callout box but I can't. So I deleted that view and make a new one and so, found my handles back again. Thanks.
can“t see the door handles!
Tue, Jun 30, 2009 at 7:12:51 AM
12
Roof Shape Handles
Fri, Feb 6, 2015 at 10:28:04 AM
Door handle not on a door plane
Wed, Apr 5, 2017 at 11:18:14 PM
Blue items show up red
Mon, Dec 9, 2013 at 4:14:26 PM
Can one crop Viewports GRAPHICALLY (with handles, rather than explicitly) R08
Mon, Oct 21, 2013 at 4:39:23 PM
12
Page generation time: 1.6439
