Forums >> Revit Building >> Technical Support >> Tilting Walls in revit 2009??
Fri, Jun 27, 2008 at 1:40:22 PM | Tilting Walls in revit 2009??
davidverret
Has anyone been able to tilt a basic wall perpendictuar to the plate line?
Fri, Jun 27, 2008 at 2:36:58 PM | Tilting Walls in revit 2009??
gustavopardo
nope but you can make the wall from a mass, it works ok
Fri, Jun 27, 2008 at 3:08:28 PM | Tilting Walls in revit 2009??
lunchtrayrider
3.5 Stars: 7 Votes
don't walls generically start perpendicular to the plate line?
I like scooters. and motorcycles.
Fri, Jun 27, 2008 at 3:59:10 PM | Tilting Walls in revit 2009??
vanostran
vanostran Avatar
3 Stars: 2 Votes
Not if you've had too much to drink.
Fri, Jun 27, 2008 at 7:08:31 PM | Tilting Walls in revit 2009??
lunchtrayrider
3.5 Stars: 7 Votes
dammit i knew there was a problem.  where is the parametric data line to refill my drink whenever it reaches the bottom of the cup?
Tilting Walls
Sat, May 25, 2013 at 9:37:51 AM
problem joining walls and structural columns in Revit 2009
Tue, Mar 16, 2010 at 6:27:19 PM
Revit IFC export and NavisWorks 2009
Tue, Nov 18, 2008 at 11:15:34 AM
RAC 2009 Columns, Beams & Walls.
Fri, Sep 26, 2008 at 10:41:21 AM
REVIT Architecture 2009 Basic Architectural Convention question [ 1 2 ]
Tue, Oct 21, 2008 at 8:19:58 AM
15
Page generation time: 4.0791
