23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Sections cut on mulitple sheets
10 Posts No Rating |
I am using revit arch. 2008 and i am cutting the same section on multiple sheets but when i cut the section on a different sheet it still says that it is cut on ther first sheet i cut it on is there a way to reference the same section put have the section tag say that it is cut on the the sheet i place it on?
3 Posts No Rating |
There is a check box to reference other view on the top options bar. After that is checked then a pulldown populates to select a list of sections to reference.
when i do that the section mark still says that it is cut on the first sheet. for example the first time i cut the section it was on sheet A6.1 when i reference the section on sheet A6.2 it says that it is cut on sheet A6.1 i need it to be cut on sheet A6.2.
3 Posts No Rating |
So you want multiple references for each sheet the section is cut. The reference is to the first cut. You'd have to use an unintelligent label to get multiple references.
what is an unintelligent label? and how do i place it?
3 Posts No Rating |
A label can be added to the Section Label family you are using with an instance parameter that then can be manually editted.
Exporting mulitple sheets to cad at once |
Thu, Feb 25, 2010 at 1:15:43 PM
Split a an elevation marker up for mulitple sheets |
Tue, Oct 4, 2016 at 2:29:34 PM
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain |
Sun, Dec 2, 2012 at 7:34:52 PM
Aligning Dependent View across Sheets |
Wed, May 7, 2008 at 11:41:51 AM
Easy way to turn off all but specific sections? |
Thu, Jan 21, 2010 at 1:59:00 PM
