Forums >> Revit Building >> Technical Support >> Thickening slab edges.
Fri, Jun 27, 2008 at 5:25:55 AM | Thickening slab edges.
Vibrator72
Using Revit Architecure 2009:
I want to thicken the edge of a ground floor slab.  When putting a sweep on the edge of the slab, the bottom part of the profile shows (in section) below the hardcore/insulation etc. but does not cut it/obscure it above. I don't want to 'cheat' by drawing a masking object in the view.  (The ADT users will be pleased if I can't solve this one!).
Fri, Jun 27, 2008 at 10:01:59 AM | Thickening slab edges.
TABEST
4 Stars: 4 Votes
Try joining the geometry.  See if that works for you.
Thu, Jul 3, 2008 at 3:19:18 PM | Thickening slab edges.
mebowles55
Was this issued resolved. I am having the same issue as Vibrator72. The solution suggested by TABEST does not work for me.
 Thanks.
slab thickening below hardcore
Wed, Jan 12, 2011 at 5:26:21 AM
Mid slab foundation thickening
Tue, Jul 31, 2012 at 7:58:11 AM
Adding Reinforcement to a Custom Slab Thickening Family
Fri, Apr 30, 2010 at 12:27:08 AM
Cutting floor slab edges out of pads
Mon, Oct 25, 2004 at 10:43:54 PM
Slab Egdes & multicategory schedules.
Mon, May 16, 2011 at 2:04:35 AM
Page generation time: 0.0825
