Forums >> Revit Building >> Technical Support >> Convert Generic Model floor based Generic -> Generic Model
Fri, Jun 27, 2008 at 4:01:11 AM | Convert Generic Model floor based Generic -> Generic Model
sabaka
Revit Architecture 2009
Is there a way to convert Generic Model floor based to just the Generic Model?
Fri, Jun 27, 2008 at 11:17:46 AM | Convert Generic Model floor based Generic -> Generic Model
TABEST
4 Stars: 4 Votes
kinda, what I do is copy everything into the generic model family.  Bad news, detail stuff can't be copied, between families, so you end up with ony model lines and geometry.  No imports, symbolic lines, etc...  Depending on the difficulty of your family, I usually just start over... Sorry there is no "good" solution that I'm aware of... GL
Fri, Jun 27, 2008 at 3:02:18 PM | Convert Generic Model floor based Generic -> Generic Model
sabaka
It was past 1am when I started the family and didn't really pay attention to the "floor based" part in the template name. Luckily, it wasn't too complex, redrawing it took less than half the time of the original one since I was able to copy a few things.  Smile
generic model family not cutting in section
Tue, Jan 11, 2011 at 7:14:50 AM
Generic Model Materials
Wed, May 18, 2005 at 5:03:38 PM
How to create a Sun Pipe family using a Generic model roof based
Fri, Apr 13, 2007 at 1:58:41 PM
Multi Level Generic Model
Fri, Jul 15, 2005 at 7:43:27 PM
Controlling Length of Floor Based Generic Model
Tue, Jan 4, 2011 at 12:11:58 PM
Page generation time: 1.2426
