Forums >> Revit Building >> Technical Support >> Fascia Sweep not mitering
Thu, Jun 26, 2008 at 4:16:45 PM | Fascia Sweep not mitering
jslwa55
Here's my problem! Please help!
 I am trying to miter the fascia as it turns from the hip roof to the gable roof. I can't figure this one out....
Tue, Aug 25, 2009 at 8:05:28 AM | Fascia Sweep not mitering
RevitNOOB
RevitNOOB Avatar
i have this problem also.  the only way i can solve it is using a plumb two cut on the roof (which has its own problems) but i found that a roof that is pretty deep, 7"-9", you can use a 6" 2 cut plumb to get it to clean up.  but becareful, you will find out later why it has its own problems in DD's or CD's.
Tue, Aug 25, 2009 at 12:39:18 PM | Fascia Sweep not mitering
tim123
4 Stars: 19 Votes
I can't download a PSD file on this computer, but if you do the fascias at the same time, they will mitre automatically.  If you do them separately they don't mitre.
By the way, the easiest way to show an image is to to 'Print screen', open Paint and paste it.  Save it and by default you have a JPG that can be opened on any computer.
Tue, Aug 25, 2009 at 12:48:49 PM | Fascia Sweep not mitering
RevitNOOB
RevitNOOB Avatar
the problem i have found is also if you create the profile of the fascia on the left side of the crosshairs it will not clean up even if you create it all at the same time.  if i could upload a rvt file i could show you but i cant get it lower than 5mb.
Tue, Aug 25, 2009 at 1:11:14 PM | Fascia Sweep not mitering
tim123
4 Stars: 19 Votes
Just upload the profile.
Tue, Aug 25, 2009 at 1:20:38 PM | Fascia Sweep not mitering
RevitNOOB
RevitNOOB Avatar
here it is.
Edited on: Tue, Aug 25, 2009 at 1:21:53 PM
Tue, Aug 25, 2009 at 2:15:07 PM | Fascia Sweep not mitering
4 Stars: 205 Votes
Is this Fascia a little BIG?? Only in the Gable you have the problem right?? what i do was change a little bit the angle of the fascia, don't solve the REAL problem but...
To do that i think i use a "In-place" - "Solid sweep" with that profile.....
Tue, Aug 25, 2009 at 2:18:55 PM | Fascia Sweep not mitering
4 Stars: 205 Votes
This is with Solid Sweep with that profile....
Tue, Aug 25, 2009 at 2:27:22 PM | Fascia Sweep not mitering
RevitNOOB
RevitNOOB Avatar
i will try changing the angle like you did but i am afriad that i will just have to hide it all in the wall sections and details...yes it is big but the designer doesnt care he only wants it right...so guess who has to have the head ache of fixing it...
Tue, Aug 25, 2009 at 2:32:00 PM | Fascia Sweep not mitering
Thread Post Kudo! #10
4 Stars: 205 Votes
So, use the In-place with Solid sweep....
Tue, Aug 25, 2009 at 2:43:30 PM | Fascia Sweep not mitering
#11
RevitNOOB
RevitNOOB Avatar
dude - i am giving you a five star rating!  that in place family worked...you are now my favorite revit user!
Tue, Aug 25, 2009 at 2:49:23 PM | Fascia Sweep not mitering
#12
RevitNOOB
RevitNOOB Avatar
still a little weird at the corners but it is much better then what i was doing...having the ends crash through each other was not acceptable
Tue, Aug 25, 2009 at 4:01:19 PM | Fascia Sweep not mitering
#13
RevitNOOB
RevitNOOB Avatar
last thing, if we can solve this problem i will not have any more issues with this stupid fascia.  if i start the sweep on the eave the rake is wrong under the gable, if i start on the gable the eave is wrong...any suggestions.  something about the transition from one side to the next rotates the fasica...i would like it to have the top part vertical like the eave is showing but have the rake vertical too.
Sloped Roof Fascia
Wed, May 29, 2013 at 1:23:20 PM
HOW DO I ADD NEW FASCIA?
Tue, Mar 13, 2007 at 3:58:46 PM
Fascia on Sloped Glazing
Tue, Aug 23, 2005 at 11:58:53 AM
fascia on two different sloped roofs
Thu, May 28, 2009 at 1:01:04 PM
roof fascia
Wed, May 23, 2007 at 4:25:22 PM
Page generation time: 0.1057
