Forums >> Revit Building >> Tips & Tricks >> Wall Thickness variable
Mon, Apr 11, 2005 at 8:02:01 AM | Wall Thickness variable
tecno
Good morning, I am a newbie therefore perhaps my question is foolish. Do I have to insert a wall whose thickness is varying, as can I do it? (The varying thickness is in plant, not in height....)
Mon, Apr 11, 2005 at 1:43:17 PM | RE: Wall Thickness variable
arnosandoval
5 Stars: 3 Votes
IF YOUR WALL THICKNESS IS IN PLAN, YOUR BEST BET IS TO USE A STACKED WALL SYSTEM. YOU CAN DETERMINE THE HEIGHTS OF EACH WALL SYSTEM THAT BECOMES PART OF THE STACKED SYSTEM . THIS IS A NEW FEATURE AVAILABLE IN REVIT 7.0. HTH
Tue, Apr 12, 2005 at 7:45:38 AM | RE: Wall Thickness variable
tecno
Thanks about your answer but my problem is other. (Sorry i'm italian user...english isn't my 1st language :-)) i've done a simple example: normal wall was created with revit family, while i want create other wall (with thickness variable) with same mode... How i can do it? Stacked wall system is other method... i've revit 7.0 thanks and sorry
Tue, Apr 12, 2005 at 8:50:47 AM | RE: Wall Thickness variable
arnosandoval
5 Stars: 3 Votes
Ok, I see what you mean. Your best bet is to create an in-place family, choose wall, so that your mass behaves as a wall and the using your extrusion tool create the wall. That would be the easiest way of doing . HTH
Tue, Apr 12, 2005 at 10:24:37 AM | RE: Wall Thickness variable
tecno
Arnosandoval thanks, but be patient.... I have done as you have told me, the wall is created and inserted in the abacus, but I don't succeed in inserting a door or a window. Where am I wrong?
Tue, Apr 12, 2005 at 10:42:57 AM | RE: Wall Thickness variable
arnosandoval
5 Stars: 3 Votes
No problem just trying to help What is the wall made of, is there a cavity inside(thus built from a series of walls) or is it monolithic? Think about how that wall is constructed. If that is something you dont care about. Try inserting the windows and door in elevation, that seems to work See attached HTH
Tue, Apr 12, 2005 at 11:07:50 AM | RE: Wall Thickness variable
tecno
In elevation? boh..is in option of door properties? i want to do like in your example, this is that i want... can do a capture of this 'elevation' option? sorry about lost time....
Tue, Apr 12, 2005 at 11:13:59 AM | RE: Wall Thickness variable
arnosandoval
5 Stars: 3 Votes
Here is the file for you to noodle with. Hope this helps.
Tue, Apr 12, 2005 at 11:37:44 AM | RE: Wall Thickness variable
tecno
yeah thanks very much..with your file i have resolve it... my probles was understand your word 'elevation' LOL in italian elevation sound like PROSPETTO while prospect (similar to prospetto) sound like prospettiva..... counfusion? yes a bit !!! :-) thanks for helps !!!
Variable Thickness Wall?
Fri, Feb 10, 2017 at 6:09:58 PM
Roof with variable thickness on sloping framing
Wed, Jan 20, 2010 at 10:12:06 AM
Wall layer thickness turned "variable"
Wed, Aug 21, 2013 at 3:25:34 PM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Sloped solid roof with variable thickness
Tue, Feb 21, 2017 at 4:09:24 PM
Page generation time: 0.9178
