Forums >> Revit Building >> Technical Support >> Mirroring an entire project
Thu, Jun 26, 2008 at 1:14:01 PM | Mirroring an entire project
ssprague
We have an 21,000 sf project that had all of the construction documents completed.  The building needs to be completly mirrored.  We would like all of the reference sections/elevations and text to mirror with the building.  Any suggestions????
Thu, Jun 26, 2008 at 2:04:43 PM | Mirroring an entire project
coreed
coreed Avatar
4 Stars: 16 Votes
i haven't used it. but Revit 2009 have a Mirror Project function.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Feb 13, 2009 at 12:40:29 PM | Mirroring an entire project
JHanby
3.5 Stars: 3 Votes
We just mirrored a big project and everything with the model mirrored correctly.  It was the annonations that are screwed up.  All our left aligned text became right aligned, no big deal to correct.  The interior elevations and sections are the correct views but the tags themselves mirrored.  How do I get the interior tags to match the correct views?  We finally upgraded to version 2009 just so we could mirror this project.  Smile
Fri, Feb 13, 2009 at 9:34:07 PM | Mirroring an entire project
ScopeDrafting
Had the same problem as you JHanby the internal elevation marker did not point to the right elevation it was 180º out. As  a work around I just switched the labels on the sheet. Not ideal. If there is another solution that does not involve redrawing the 2D details I'd love to know.
Mon, Feb 16, 2009 at 8:45:08 AM | Mirroring an entire project
JHanby
3.5 Stars: 3 Votes
ScopeDrafting,  I guess the way you did would work but some of my elevations are only on the one side.  So what I have been doing is hiding the original elevation mark in the view and then create a new elevation referenceing the original elevation view.   Other than starting from scratch I couldn't think of another way to do it.Edited on: Mon, Feb 16, 2009 at 10:05:41 AM
Edited on: Mon, Feb 16, 2009 at 10:18:36 AM
Mirroring entire project- "copy" check box greyed out?
Sun, Apr 23, 2006 at 6:44:57 PM
Mirroring entire plan?
Wed, May 4, 2011 at 11:55:15 PM
Mirroring
Mon, Oct 14, 2013 at 4:28:29 PM
How to copy over entire project
Wed, Nov 7, 2007 at 10:38:31 AM
Move half of entire project down vertically
Tue, Aug 4, 2015 at 10:35:42 AM
Page generation time: 1.3169
