18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> Arch Link
When i turn on my arch linked model all i see is doors and windows. In order to see the walls i have to turn the view discipline to architectual. Is there a way to see the walls without doing this, it gets old having to keep changing over and over
If you are using structure, set the view to coordination. The easiest thing to do is set up a view template you can apply to each view. But, most important! Have this as a default in your template. Having a good template will save you tons of time with view and visibility properties. Unfortunately, you can't create view templates for a linked-model visibility settings. I hope this changes for 2009!
Cool thanks
When I import REV. ARCH Link, it lands way outside my work space |
Fri, Oct 9, 2009 at 12:22:40 PM
Arch link on top of Structure |
Wed, Jul 20, 2011 at 4:27:19 PM
Central File & its Arch link - disappeared! |
Mon, Aug 29, 2011 at 2:54:22 PM
Arch Link and wall view ranges/visibility graphics |
Wed, Apr 21, 2010 at 10:06:47 AM
Printing Arch. Sheets through the link |
Tue, Aug 11, 2009 at 10:58:26 AM
